Ducato wheel arch rust
Discussion in 'Fiat' started by GJH, Oct 8, 2013.
  1. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,337
    34,845
    When we had the van serviced earlier this year the mechanic said there were signs of rust starting to appear under the front wheel arches. Circumstances soon afterwards meant that I couldn't look at it and then I have to admit I forgot about it.
    Anyway, I had a look on Sunday and happily it wasn't serious. Basically paint lifting over an area about the diameter of an orange. I gave it a good clean up with a wire brush which confirmed that it was just a patch of surface rust. I painted it with Flag Rust Converter yesterday then painted on some Hammerite Underbody Seal today, pleased that I got to it before it became anywhere near serious.
    Might be worth a quick check if you have a 9/10 year old Ducato based van.
  2. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    They all go there - another place to keep an eye on is in the engine bay, where the flich meets the bulkhead/arch. Water sits there over winter, and can cause rusting issues. Also, behine the brake pipes as they go under the body - holds crud there, rots break lines and there is no way of checking easily unless you remove the clip and clean regularly. Most loss of brakes is caused by pipe failure here.
    • Like Like x 1
  3. Gromett
    Gromett Funster
    Feb 27, 2011
    7,998
    14,361
    UK
    I had the same notification on last years mot...
    Thanks for reminding me :thumb:
Similar Threads
  1. rogher
    42
    1,228
  2. Louis
    64
    2,630
  3. JWF1
    16
    687
  4. Arzedby
    14
    554
  5. SteveandDenise
    16
    751
