Can anyone shine any light on a problem with my 2003 swift sundance (ducato based) speedo fault. When starting engine from cold & running at idle with vehicle stationary, the speedo fluctuates anywhere between 0-80mph as soon as I touch the throttle speedo returns to zero. Then when I start to move even just creeping from rest the speedo goes haywire fluctuating as above then after a couple of miles all seems to settle down to normal, no other gauges i.e fuel,temp & rev counter are not affected & all read normally, the only thing that has occured at the same time & has only happened once is no engine speed response to throttle pedal position. I have read threads where the speedo doesn't register at all for a few miles, the part at fault for this syptom seems to point to a fault with the speed sensor in the gearbox.
