Ducato Speedo dial
Discussion in 'Motorhome Chat' started by grandadbaza, Apr 27, 2011.
  1. grandadbaza
    grandadbaza Read Only Funster
    Jan 20, 2010
    9
    Habrough, N E Lincs
    Just wondered if anyone had changed a KPH speedo dial to a MPH one, and had the old KPH one lying around , would like to buy it if anyone had one , to fit latest Ducato
    :thumb:
    Baza
  2. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Errm! Is that called "Clocking"?
    Doug...
  3. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
    If you already have an MPH dial it has the KPH also on the dial, although in smaller digits.
    You can also switch over the trip computer into Kilometers using the mode control switches.
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,088
    17,759
    YO11 2BD
    only if you dont inform the authorities.
    speedo's break, speedo's get replaced.
  5. grandadbaza
    Jan 20, 2010
    9
    Habrough, N E Lincs
    I do not want to do anything illegal , I dont want to change the mileage, thats on a digital display anyway, I just want to change the dial face on the speedo to KPH as I struggle to read the small red numbers on the kph display without specs on ,going on extended trip in euro and it would be easier to keep eye on speed if if I changed dial
    Seen various sites where you can by Mph dials but not Kph ones
    Baza
  6. Squire
    Squire Read Only Funster
    Dec 30, 2010
    324
    60
    Off topic with your original post, I know, but I found that the speedo reading on my Garmin sat-nav was better to read - and more accurate - that the Fiat's speedo - and it's switchable between metric and imperial too. They're so cheap nowadays that it may even be cost effective ....
  7. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,919
    1,944
    Warwickshire
    Lockwoods make replacement dials for many vehicles. That's where I got a Sprinter MPH dial to replace the original KPH one. I am not sure if they make the 'reverse fit'.
    However, if you replace the MPH dial (which also shows smaller kph markings) with a KPH dial, that is unlikely to show MPH. It is illegal to drive a UK registered vehicle without MPH indication. I know some people (and importers) mark the 30/50/70 mph positions with stickers, but the law requires that the mph markings are visible under all conditions: i.e. they must be illuminated at night. That is quite difficult to achieve with markings stuck on the 'glass' of the dial cluster.
