Ducato: replaced front wheel bearing-now squeaky (1 Viewer)
JEB
31
14
UK -sussex
I`m a newbie
Had front n/s wheel bearing replaced.it has now developed a squeaky noise at low speed...say 10 mph, which disappeared when you dap the foot brake and then start up again when released. The same noise is now apparent at 30 mph and louder. Thought it maybe due to dust on brake pads...would appreciate any thoughts potential causes...
Jan 22, 2013
1,253
60,218
London SE
A class Adria vision I707
since 1971
Yep loads of ideas:winky: but more likely only the brake pads squeaking,
Remove pads give a clean and some anti squealing compound to the pad backplate will suffice, you could also use copperslip,:thumb:
greyman1
374
279
manchester
9 years motorhome / 10 years campervan
squealing is usually down to brake pads needing to bed in with the discs ,this is esp so with new pads. infact a lot of pads now come with chamfferd edges to help eliminate the problem.
TerryL
6,184
8,186
North East
Low Profile
I believe that Ducato front brakes have an anti-squeal shim fitted between the pad and brake cylinder. Might have been accidentally left out.
MikeD
3,936
3,697
London
IH PVC
Since 2012
If it has only happened since the wheel bearing has been replaced it is almost certainly something to do with that work.
If it has got noisier or worse since then it is something that is deteriorating.
I suspect the new bearings were not seated in the rim/shaft properly allowing the disc to move a little bit. Which then allows the brake pads to rub probably on the rust on the discs.
I doubt they would have disturbed the pads in the calipers so they should not be the cause.
Jack the front wheel up and have a look for any movement that should not be there.
Badknee
7,407
412,669
notloB
Vantage Neo
Living the dream.
If it stops with a dab of the brakes it's the brake pads not sitting straight, you could take it back and ask them to sort it.
greyman1
374
279
manchester
i would have thought that after almost 5 months this problem will have been sorted !!!!
