Ducato parts list / numbers - DESPERATE.
Discussion in 'Fiat' started by Trikeman, Oct 17, 2013.
  1. Trikeman
    Trikeman Read Only Funster
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Hi All,
    does anyone know where I can get hold of a parts list/manual for a 2006 Fiat Ducato 2.8JTD. I am specifically looking for the cooling circuit. I am trying to get a part number for Fiat to get the part - I tried today with Fiat parts, but it appeared without the part number the guys wouldn't to be able to get to work.:Sad:
    I am in desperate need of the steel coolant pipe that goes across the top of the rocker cover, bolted at the lift bracket on the offside and on the nearside on side of head/pipe. Both ends have rubber hoses attached, offside down to waterpump area, near side hose goes onto the rear base of expansion tank. The pipe itself goes the full length of the top of the engine and bends under the top intercooler hose. A couple of electrical wire brackets are also along the pipe. The pipe is the one marked with a red arrow.
    Piccy.
    [​IMG]
    Any help would be greatly appreciated.
    Regards and thanks,
    Trikeman.:Wink:
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,322
    YO11 2BD
    Try a different dealer, that ones a waste of space.
    all they need is your reg number or VIN plate chassis number and a description of the part.
    • Like Like x 2
  3. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    papajohn is right that should be one of the easier parts to ID. go to another dealer. :thumb:
  4. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,157
    8,069
    DERBYSHIRE
  5. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,180
    12,529
    goole
    like papajohn quoted engine code reg no and the part should cum up dealer trying to milk
    you get another dealer :thumb:
  6. Trikeman
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
  7. Trikeman
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Wowah!!!!!!!
    Just discovered that this is quite a common problem with the 2.8 Ducato motors.
    With some internet research (2 hrs or so) it appears the foible that can catch owners out.
    The pipe can be bought from Fiat (fiat 13394557080) but even Fiat know about this 'issue'. Apparently it used to be just a rubber hose from one side of the engine to the expansion tank on the other but Fiat (bless them) changed to the metal pipe to ease build at the factory.
    Anyone with this pipe should check them - several haulage/courier companies have removed these pipes from all the Ducatos in their fleets due to the problem. Mine is identical to the issues suffered by them and others.
    The bracket on the off/side vibrates and fractures the solder (pipe to bracket) which then leaks and on the opposite side there is a bracket/support that shears completely leaving the whole pipe to vibrate - thus the solder fracturing.
    After seeing this and the amount of them being reported as failing I will be doing as others recommend by putting a one piece rubber hose from the water pump to the expansion header tank and just using this steel pipe to support the rubber hose.
    Please, everyone with a Ducato - check your pipe if you have one, it's a catastrophe waiting to happen.:Eeek:
    Regards,
    Trikeman.:Wink:
    • Like Like x 1
Similar Threads
  1. rogher
    42
    1,219
  2. kenandjude
    7
    675
  3. Louis
    64
    2,591
  4. JWF1
    16
    680
  5. yellowapple
    659
