Ducato owners beware
Discussion in 'Tech/Mech General' started by PP Bear, Nov 4, 2015.
  1. PP Bear
    PP Bear Funster Life Member
    Apr 5, 2013
    2,273
    6,903
    UK
    image.jpg It certainly pays to be a Funster and all the invaluable advice they can offer. Often based on personal experience and expertise :)
    If you followed this thread,
    http://www.motorhomefun.co.uk/forum/threads/general-maintenance-diy.118579/
    then you'll have know that I had recently inspected the offside front and rear discs and pads and declared them sound and serviceable, however I never actually removed them and stripped the brakes down.
    In my OP I was advised by @Lofty1 and backed up by @davenewel (http://www.davenewell.co.uk/) that I should strip out the pads and check they're fully serviceable. I took the advice and put the motorhome in the garage again and inspected all the pads. Good job I did as the last set to be inspected duly fell apart as predicted (see photos)
    If I hadn't had taken the advice and had a full strip down inspection, then goodness only knows how many more miles I'd have driven before suffering a catastrophic breakdown, or even worse!!!!
    New pads front and rear are now on order and I'll collect them tomorrow. Good job I've access to one of our military vehicles, or I'd be left trying to have them delivered to the base.
    Also found a self tapping screw in the rear tyre, but luckily it hadn't done any damage, along with a small maggot that somehow likes to live in the tread of my tyre!!
    My vehicle is a 2006 2.8 JTD Ducato, with just over 25000 miles on the clock. The vehicle is in an immaculate condition, especially considering it's nearly 10 years old. The pads looked really good until stripped out. So the question now is.....how many more are there out there that should be changed. Might be worth getting them checked for peace of mind. If it's a garage or a Halfords Auto Centre, get them to fully remove the pads. My last trip to a Halfords, resulted in them merely measuring the thickness of the pads, which in this case, just wouldn't have found the problem. They need to be removed.
    They're actually the easiest set of pads I've ever removed. Well within the abilities of the competent mechanic and their home DIY skills
    Thanks fellow Funsters, all dam good advice and well followed by the Bear. Just need to fit them now and then run them in.
    • Like it Like it x 17
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,112
    17,779
    YO11 2BD
    The maggot will be the last indication of that rabbit you ran over last month. :D
    • Like it Like it x 7
  3. PP Bear
    Apr 5, 2013
    2,273
    6,903
    UK
    Tasted delicious :rofl::clap2::cheers:
    • Like it Like it x 2
  4. Masman
    Masman Funster
    Sep 25, 2009
    313
    205
    south yorkshire
    Had new discs and pads change last year.last two MOTs had advisory that discs where pitted.there was plenty left on pads but looked a bit rough.van only done 40k.
  5. Derbyshire wanderer
    Derbyshire wanderer Funster Life Member
    Mar 30, 2014
    510
    867
    Derbyshire
    My last van was a 2005 and in 2009 when I bought it it had done 18000mls but the brakes squeeled like a stuck pig. I removed the pads as you have done and one of them was almost completely delaminated. If the friction material had actually come away, the steel backing plate could have easily jammed in the calipers space and caused either extra damage or a disaster.
    New pads fitted for about £25 and 45 minutes of my time.
    It is worth noting that the main dealers now rarely remove the wheels to check the brakes on a service (to keep the service times down which pleases the lease companies!) This sort of problem can only be found with the wheel removed. Stripping and cleaning the pads is the only way to be sure that delamination has not started to occur.
  6. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,977
    11,219
    Glasgow
    Thanks PP Bear. Vanessa is going for her service in the morning so I will advise the garage of your comments(y)
  7. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,833
    8,963
    NW England
    Every other annual service I ask them to strip and inspect the brakes, regardless of mileage or what the schedule says.
  8. PP Bear
    Apr 5, 2013
    2,273
    6,903
    UK
    It's such a good idea as it's the only way to be sure. Ask them to remove all the sets, just to be sure. I didn't find my broken one, until I removed the last wheel :)
    Every days a school day, no matter how old I get :blusher:
    It's something that I'll keep my eye and mind on now, it's all good advice and at £53 (parts only) to replace all sets, I don't think it's that expensive either :)
  9. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,192
    3,017
    Kendal, Cumbria
    I wish I'd seen that a couple of months ago. I had my MoT early September prior to which I checked all bushes, boots, bearings, and pads. Like you I did not remove them - just a visual check with the wheels off. They had around 6mm left. The MoT man mentioned that they were getting close to being worn out but didn't give me any advisories. On my way to the Lincoln show the NS front spat out the friction lining from one pad. The only reason I knew this had happened was that the brakes briefly developed long pedal travel & subsequent braking caused a grinding noise from the affected brake. The brakes continued to work apparently normally (no pull - which surprised me) for the last 10 miles or so to the show and whilst there I booked in with a local brake specialist for the Monday. I found making the call quite traumatic as it was the first time I'd ever arranged (or made) a visit to a vehicle repair establishment. Anyway I had the repair done and watched them like a hawk throughout. They did a decent job & charged me £169 for two discs & a full set of pads which seemed very reasonable. In the past I've seen pads down to a couple of mm just starting to flake (not mine!) so I was somewhat surprised by the failure. It's possibly down to lack of use of the van & possibly moisture penetration / adhesive failure. Either way the advice to remove for examination once a year is most definitely sound (if a little tardy :D:D).
  10. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    5,928
    9,006
    Lincs/Cambs border
    During the eleven years of ownership, our MH has had 2 x new sets of front discs, and 3 x new sets of pads. None of the old pads showed signs of cracking or delamination from their backplates. I am by no means a heavy breaker.
    Years ago, it was the pads that wore away quicker than the discs, but not so these days, with the use of Kevlar in the pad lining manufacture. :eek:
    At sixteeen years old, she is still on the original rear brake shoes. ;)
    Cheers,
    Jock.
  11. PP Bear
    Apr 5, 2013
    2,273
    6,903
    UK
    Thanks Jock. I've decided that I'll change both front and rear. Euro Parts have them at 50% discount, so just over £50. It makes great sense as I'm parked up at the moment in the garage. It's been completely cleared out, so just me, EHU, 2 pits and 3 bays to use, so a perfect opportunity to the do the job inside in the relative warmth :)
    Also I found one of those new fangled inventions in the corner, a porcelain toilet :Eeek: Quite a novelty, they even flush. Perfect for "dumping" my black:notworthy2:
  12. Lofty1
    Lofty1 Funster
    Oct 7, 2015
    176
    772
    newark
    Just to make things clear,When on service the only check is the thickness of the pads they are not removed as most commercial vehicles have them changed every year or so. As our vans tend to be low mileage time is the biggest killer of brakes, Most pads are easy to change but beware of Iveco calipers as the pistons in the calipers screw in and are difficult . Finally if unsure or not confident there are plenty of competent people on site who will help I'm sure. I am in the Newark area if anyone needs help.
  13. PP Bear
    Apr 5, 2013
    2,273
    6,903
    UK
    Well I've changed both sets of pads, so it's back to peace of mind again for a few more years :)
    It never ceases to amaze me with the vehicle. More Autotrail shoddy work and more wiring. No wonder so many people have electrical problems, if my wiring harness is anything to go by :Eeek:
    While I was replacing the rear pads, I could clearly see some wires that were far too long for their application and were simply laying on the wooden "shelf" that hides the water tanks. I simply picked it up and it came out far enough to go under my rear wheel, should it have vibrated out. The other wasn't even insulated and had crimped connectors fully open to the elements and again, just sitting on the board :swear2:
    Shoddy, shoddy rubbish. I wish I could watch them produce these expensive vehicles, I'd soon stage inspect them. I wouldn't let a single board or panel be put in place to hide such rubbish, until I'd inspected it for craftsmanship. Looms and loose wire like the ones I found on mine, wouldn't get past until properly secured and tidied up!! Standards Autotrail, try applying them.
    Ended up removing the board, securing the wiring and added extra lagging to the fresh water tank. Also greased the rear axle while I was at it :cheers:
    • Like it Like it x 6
  14. Tootles
    Tootles Funster
    Sep 14, 2013
    9,253
    33,166
    Lancaster
    Well, I did tell you that your small maggot wasn't up to common assault.......(y)
  15. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,164
    1,271
    Dronfield - Derbyshire
    Shocking !!! Who are these clowns that put motor homes together?
    They are certainly not motor engineers (or electricians) Bloody amateurs!
    If they think if we cant see it, it doesn't matter,' just bodge it up with tie wraps and tape, it's criminal considering the price we pay for this shoddy workmanship.
    One more observation.
    Never buy cheap brake pads. If they are cheap rubbish you will have rubbish brakes for the next 20,000 miles.
    I only ever buy Ferodo.
    I used to race with their pads exclusively but I was once sponsored to a free set by another large manufacturer - I nearly died at the first corner - never again.
    I even asked their top rider how he managed with such crap pads, looking around he whispered 'not in the front'. No one ever used the rear brake!
    You wanna guess what make he was using in the front?
  16. PP Bear
    Apr 5, 2013
    2,273
    6,903
    UK
    I use these....
    [​IMG]
    Pagid has a strong history and earned its reputation with vehicle manufacturers like VW Group, DaimlerChrysler,Opel/Saab and Porsche.
    Through the years a philosophy of quality and performance has ensured Pagid has evolved into the choice of vehicle manufacturers globally.
    Pagid's reputation for high performance friction is substantiated by O.E. approvals with:
    • Audi S4, S6, RS 6, TT, Q7
    • Mercedes C-Class, SLR
    • Opel Vectra OPC
    • Lamborghini Murcielago
    • Aston Martin Vanquish
    • VW Phaeton, Touareg
    • Porsche 997 GT3 RS, Cayenne
    • Leading the field in both O.E. and aftermarket friction development, Pagid is working in partnership with the world's leading brake and vehicles manufacturers for high performance cars.
    I'll let you know if they're any good by the first corner :)
  17. Cleve
    Cleve Funster
    Aug 27, 2015
    387
    590
    North West Europe
    Just as a by the way. Don't forget brake fluid is hydroscopic and that needs to be changed periodically. If not on a long down hill, possibly riding the brakes you could boil up the fluid, have the brakes fade and possibly fail altogether. Them windy roads don't always have emergency escape lanes.
    I had a thruppenny bit half a crown experience in my old type 2 VW on a hill on the south coast years ago. Made worse by being drums all round of course.
    Clive
  18. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,164
    1,271
    To perform a proper test ------
    You'll need to arrive at a 90 degree corner at about 145 mph and brake at the 200 yard marker -- definitely not one yard past it.
    If you do manage to get around the corner, then they are good enough.
    I'm sure there is nothing wrong with Pagid components, a well respected manufacturer with a strong reputation to maintain.
    As a posed to some 'no name' made in China.
  19. WAG2CRU
    WAG2CRU Read Only Funster
    May 31, 2012
    378
    496
    Argyll
    Hagrid's brakes were stripped and cleaned during a service in September, he was coming up to 3 years old and 30K miles, we had just completed a trip through the Alps so I was surprised to be informed that the disks where "As New" and, the pads only about 20% worn.
