Ducato ignition switch
Discussion in 'Tech/Mech General' started by Forester, Aug 24, 2014.
  1. Forester
    Forester Funster
    May 21, 2012
    159
    175
    forest of dean
    Whilst on our recent trip to Germany starting our 2003 Ducato based Adria (2.8JTD) became difficult. Its not an engine problem its the ignition switch. The spring that returns the key once stated to its normal on place seems to have become over strong and although the van starts immeadiately it stops as soon as you let the key go ! It is also not possible just to turn the ignition on as you either have to turn it to start ie crank or let it go and it springs to off.
    Is this a known fault? Whats the remedy? Any ideas? Thanks
  2. Tootles
    Tootles Funster
    Sep 14, 2013
    9,123
    32,111
    Lancaster
    New switch unit, complete assembly. (pretty sure the switch has collapsed behind the lock).
    The NORMAL procedure is thus. Disconnect the battery, (engine), and remove the steering shroud. You should now be able to see the switch/lock in it's entirety. The bolt holding the unit to the steering shaft will have a break off head bolt. All you will observe is a shiny metal cone shaped 'head'. Using a fine punch, tap this head in a counter clockwise direction, until the bolt unscrews. Now you can remove the full unit, and un-clip the wiring harness at the plug.
    On re-fitting the new switch/lock assembly, loosely assemble, and tighten up the holding bolt slowly. When your happy that it feels 'right, test with your keys. Finally, tighten the bolt until the head shears off. Replace shrouding, then TEST STEERING LOCK AND FULL RADIUS OF THE STEERING before driving.
    CAUTION. If you have air bags, get agent advice before you proceed with this job.
    • Like Like x 2
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    I would say new switch required.
    Looks like either something inside has dislodged or the whole switch has started to melt.
    I doubt you can buy any parts for the switch internals.
  4. Forester
    Forester Funster
    May 21, 2012
    159
    175
    forest of dean
    This is sounding tricky and expensive.
  5. Tootles
    Tootles Funster
    Sep 14, 2013
    9,123
    32,111
    Lancaster
    • Like Like x 1
  6. pappajohn
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
  7. Tootles
    Tootles Funster
    Sep 14, 2013
    9,123
    32,111
    Lancaster
    At that age???????
  8. Forester
    Forester Funster
    May 21, 2012
    159
    175
    forest of dean
    That I guess is my question. The locks on ebay are non imobiliser according to the advert. Does that mean that if I fit one of them I can use the keys that come with them to start the van provided I remount the ring from around the lock ,which I assume is the receiver for the key transmitter, somewhere where I can place the old key so as to trigger the immobiliser. Or am I talking rubbish here?
  9. pappajohn
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    You could, but if the van gets stolen and recovered kiss any insurance claim goodbye as you over rode the immobiliser....unless you removed the redundant key every time you locked the van.
  10. pappajohn
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    They all should have an immobiliser transducer ring in the ignition switch....otherwise the immobiliser wont work.
    ALL vehicles now must have an immobiliser and have needed one for some years.
    • Like Like x 1
  11. Forester
    Forester Funster
    May 21, 2012
    159
    175
    forest of dean
    Or can the barrel be swapped from my old lock to the new one, assuming its not the barrel at fault
  12. pappajohn
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    It could if it isnt damaged which would solve the immob issue and of course, you still have the same key for the doors also.
  13. Tootles
    Tootles Funster
    Sep 14, 2013
    9,123
    32,111
    Lancaster
    Mine hasn't:):):)!!!......
  14. Forester
    Forester Funster
    May 21, 2012
    159
    175
    forest of dean
    In 30 minutes this morning got the lock off and the barrel out. About to order a new lock.
    Thanks all for the advice.
    • Like Like x 1
  15. Tootles
    Tootles Funster
    Sep 14, 2013
    9,123
    32,111
    Lancaster
    So, how did it come out?? Did you dis-assemble like I said, then press a recessed button to remove the lock assembly, or did the switch simply pull out???
  16. Forester
    Forester Funster
    May 21, 2012
    159
    175
    forest of dean
    One of the shear bolts undid with a gentle tap on a chisel. One had to be beaten violently was just about to reach for the angle grinder when it gave in. Turned key to mar and pressed the tab in the lock to release the barrel. Barrel seems to be in perfect condition so I assume the problem is in the lock, its all sprung and I dont fancy trying to take apart. There is a pin I could drift out but fear that all sorts of bits will spring out! For under £40 I have ordered a non immobiliser lock from ebay (Poland!) will see if I can use that before I fiddle with mine any more.
    Thanks again for the advice
    • Like Like x 1
  17. Tootles
    Tootles Funster
    Sep 14, 2013
    9,123
    32,111
    Lancaster
    (y)(y)(y) Keep us up to speed when the lock arrives!
