Ducato gearbox oil top-up
Discussion in 'Tech/Mech General' started by TDH, Mar 28, 2011.
  1. TDH
    TDH Funster
    Jun 22, 2009
    718
    337
    Powys/Shropshire border
    I have an old (1989) Ducato 2.5l. Can anybody tell me where the gearbox oil fill point is please?
    Thanks.
  2. ticktok
    ticktok Read Only Funster
    May 13, 2010
    41
    Kent (South Coast)
    Hi,
    I may have answered your question before in another forum but if it wasn't you here goes, the simple answer is there isn't one, the only way to do it is to drain the gearbox and refill it with the correct amount of oil. Even that is easier said than done as there is no dedicated filler hole but it can be refilled via the gearbox breather or the speedo sender or cable fitting.
    Neither are easy to see and the battery and carrier will have to be removed. You can usually feel the breather which has a plastic cap that can be pulled off then by using a hose and funnel, and patience (it is very slow) it can be done.
    Have a look here it is a 2.8 but the same box i think. http://www.fiatforum.com/ducato/231933-1998-ducato-2-8-tdi-gear-box-oil-change-top-up.html
    Hope this helps, although you may wish you had never asked!:Eek!::Eek!:
  3. TDH
    TDH Funster
    Jun 22, 2009
    718
    337
    Thanks for that (I think!). It wasn't me on the other forum although since my post this morning I have seen your reply there.
    Cheers. :thumb:
  4. betterthenatent
    betterthenatent Read Only Funster
    Aug 23, 2010
    38
    Iit was
    It was me i have a Peugeot I think mine is different
  5. ticktok
    May 13, 2010
    41
    Kent (South Coast)
    Sorry if I gave you duff info, I had a slightly earlier one than you with no level plug and I thought all the 5 speed ones were the same:Doh::Doh:
    Roger
