Ducato fuel tank (1 Viewer)
Louis
Louis
1,204
982
Anglesey
Fiat Ducato Auotrail
6 Months with motorhome(35 years tugging)
£69 at £1.10 per litre is approx 14 gallons (62 ltr)
14 gallons per 315 miles = 22.5mpg
I would say you have a 70litre tank and the gauge is inaccurate.
22mpg is about right.
Standard ducato tank used to be 70liters
I paid £1.20 a litre @ Thurrock services Saturday morning, it's either a 13 or a14 gallon, agree with your maths, but still too small for long distances, means I have to keep an eye on the gauge at 250 miles that's when to start sweating, can't chance reaching services when 300 miles are on the trip accurate or not, thanks for the info, will keep you informed
Louis
Louis
1,204
982
Anglesey
That's not what I said. How can you tell if the tank is empty if the gauge is reading wrong? I'm not having a go, just a thought. Have a look under another MH and compare physical sizes.
I'm sorry was not meant to be picky steel way, I have no reason to suspect gauge , but the amount of fuel and cost adds up to a small capacity. Will definitely sort when I get home cheers
Louis
Louis
1,204
982
Anglesey
Ok here's the latest, 172 miles on 28 litres = 27 mpg
Louis
Louis
1,204
982
Anglesey
How are you calculating that ? Trip computer or brim to brim ?
Brim to brim , zeroing the trip on two motor homes so mil ages are quite accurate. One tiny thing though. We were travelling at a steady 56mph! Not something I can do all the time when traveling long distances
Poohbear
280
473
Worcester
Swift Lifestlye 644
June 2015
Our 2015 Ducato 2.3 130 has a 60litre tank. The standard van with this same engine has a 90litre tank. For some reason they put the smaller tank on the motorhome base vehicle, however illogical it may seem (I'm guessing it is to do with payload). We're happy with a 360 mile range anyway.
43,301
49,286
Wouldn't it be easier and cheaper to fill up more often if distance is a problem.
Why wait until it's low to top up.
'Cheaper' being cheaper than fitting a long distance tank and associated plumbing.
It's suggested that driving at 70mph is using 30% more fuel than at 50mph.....especially in an un-aerodynamic brick.
Louis
Louis
1,204
982
Anglesey
Yes very true indeed, probably that will be the end result
Aug 18, 2014
23,740
133,196
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Who said I was filling up from 1/4 of a tank? I said the warning light had been on for over 20 miles the gauge on the floor, I was not going to travel any further to check accuracy of the gauge
Mine being older has the 70L tank .Very rarely do I ever let it go below half way but I did recently & then the light came on:eek: I was panicking a bit as it was 40kms home & to where I fill up & half of that was uphill. When I did get there it took 54 litres brimmed.? Which means light came on at 18-20l left. Now even at my worst I get 10kms per litre & best 14 so if the light comes on again I know I have between 180-200kms & 252-280kms .
Even looked in the book to see at what capacity left the light is supposed to appear but couldn't find anything.
Aug 18, 2014
23,740
133,196
Lorca,Murcia,Spain
Transit PVC
I was just on the Fiat forum & there was an optional 60l tank & they obviously fitted this to make payload appear better.Standard is 90l & long range 125l.
Louis
Louis
1,204
982
Anglesey
Thanks for the info, Its really a choice of more fuel less mpg but longer travel between fills or small tank more mpg and short distance between fills (also having to check gauge and trip constantly and planning service stops in time)
TheBig1
17,595
43,017
if it was me, I would ring round the commercial vehicle breakers and buy a 125ltr tank and brackets from an ex delivery van. couriers and royal mail etc all use the biggest yanks available. as they are plastic, they tend to clean up good as new
Louis
Louis
1,204
982
Anglesey
Didn't think of that !
Louis
Louis
1,204
982
Anglesey
My tank does not reach that far towards the exhaust ?
That tank in question is from a normal box van which "have" a bigger tank as standard
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Hi Lo:LOL:
Sorry had to be done
I only comment as you seem to be handling them quite well.
Have you consulted Mclaren F1 guys on fuel stop strategy yet;)
time saved along with brake pad and tyre savings (reduced turning in for fuel) should more than cover any upgrade
Your trips sound more like endurance trials or a race to me :)
If you run out completely call the RAC put kettle on and TV then chill(y)
But above all enjoy
Louis
Louis
1,204
982
Anglesey
W
Hi Lo:LOL:
But above all enjoy
Well now you mentioned it
Louis
Louis
1,204
982
Anglesey
:rolleyes:
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
Wow, you must be in a hurry to get somewhere!
You have to have your Race Awning, Hospitality, Garage set up on Thursday, Practice & qualifying Friday, Race 1 Saturday, Race 2 Sunday. Plus traveling both sides of that x 10 meetings a season, too long away from work & I have no funds to race (y)
Louis
Louis
1,204
982
Anglesey
