Ducato front coil springs
Discussion in 'Fiat' started by tony_g, Jul 27, 2013.
  1. tony_g
    tony_g Funster
    Aug 29, 2010
    387
    191
    Nuneaton,some of the time
    I've had the front coil springs on my 3.0litre Laika Rexosline uprated to get the front axle up from 1875kg to 2000kg, The old springs are Goldschmidt M11's. They seem in good nick.
    Anybody interested?
  2. BgClick
    BgClick Funster
    May 13, 2012
    347
    129
    West Mids
    I'm getting my front springs upgraded too. I assumed he old springs would b binned?
    Tel us more
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,786
    10,199
    once stressed by being used on a heavy motorhome, suspension springs are not worth fitting to another van. mind you, it may be economical for somebody to put them on a beat up builders van to get it through an mot
    i personally wouldnt fit second hand suspension, steering or brakes.... too dangerous
    • Like it Like it x 2
  4. tony_g
    tony_g Funster
    Aug 29, 2010
    387
    191
    The firm that fitted the new ones for me seemed to think the old ones would 'do a turn'.
    Laika sales material from when the van was new in 2009 stated the coil springs were 'uprated' but typically could not quantify that when I enquired prior to having an SVTech weight upgrade. It was important for me to take the front axle from 1850kg to 2000kg but the existing springs were still ok. The replacements, being a known quantity, allowed SVTech to issue the new 'plate'. :Smile::Smile::Smile:
  5. rapido9090f
    rapido9090f Read Only Funster
    Aug 12, 2013
    MK
    Goldschmitt springs
    Hello Tony
    New to this forum lark, researching new springs for my 2007 A class 3ltr Rapido Fiat based M/home, I am interested how different the Goldschmitt springs are to standard Fiat springs...mine have sagged and I need to change to something,
    Look forward to hearing from you
    Thks
    Peter
  6. tony_g
    tony_g Funster
    Aug 29, 2010
    387
    191
    Hi Peter... I have pm'd you but should add that the Goldschmidts could well have been the original Fiat fitted ones. I couldn't get any confirmation or otherwise from Laika.
  7. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,189
    15,163
    Leeds the one up North
    My front is 2100kg rated and I have no idea what springs are fitted :Eeek: what are they likely to be?
  8. cj440
    cj440 Trader
    Sep 19, 2013
    16
    5
    sunny fife
    Hi Guys, just joined the forum & finding alot of interesting info. Anyone got first hand experiance of the Gold Schmitt 4" lift front coil springs. My 08 Bessacar E789 sits very low in the front. Is there any alternative manufacturers that make an uprated spring?
    Thanks,
    CJ.
  9. Techno
    Jul 28, 2010
    14,189
    15,163
    Hi and welcome CJ
    Good question as I'd like to know more about this too
  10. TheBig1
    Nov 27, 2011
    7,786
    10,199
    i am certain that strut spacers used in lifting 4x4s could be used to raise the front suspension if it sits too low even with decent springs fitted. uprated springs often give a harsher ride so are not always appropriate
  11. Xabia
    Xabia Funster
    Jan 20, 2011
    776
    514
    Rural Nottinghamshire and Spain
    My Hymer was very nose down so last year I had Goldschmitt springs fitted by Essanjay. It made a world of difference. The vehicle is now 'level' and whilst the new springs are strongervthan the originals the suspension is much more pliable and comfort improved. I suspect thatbthe originals were bottoming and causing the uncomfortable ride.
    I believe that either you can now specify Goldscmitts on a new Hymer, or that possibly they even fit them as standard.
    If you contact them in Germany you will need to tell them the axle rates at which you run when laden and they will supply the correct spring, don't just tell them the plated weights.
    Mike
    • Like it Like it x 1
  12. Techno
    Jul 28, 2010
    14,189
    15,163
    It's not likely that springs will LEVEL my van as I am hugely in the air at the back on my 4250 heavy chassis but any improvement would be welcome.
    my front is 2100kg and we run at 1920 full
  13. cj440
    cj440 Trader
    Sep 19, 2013
    16
    5
    sunny fife
    Hi Mike,
    This is exactly the info I was after. I emailed Gold Schmitt in Germany yesterday so just waiting on an answer back. Will let you know how it goes.
    Thanks all,
    CJ.
  14. cj440
    cj440 Trader
    Sep 19, 2013
    16
    5
    sunny fife
    Ok Guys, Springs ordered, will give an update when they are fitted. May be a few weeks though as between delivery & I am going away in the MH next week.
    Cheers,
    CJ. :thumb:
  15. cj440
    cj440 Trader
    Sep 19, 2013
    16
    5
    sunny fife
    Ok, Been away for a week, came back & there is a box awaiting me with 2 coil springs inside.
    Workshops fitted them today........OMG:Eeek:...... the difference is like night & day. They quoted a 60mm lift & they have lifted it exactly 60mm. The ride quality is incredible with much more compliance. I am a very hard person to please but I can honestly say these are BRILLIANT, exactly what I was after. The roofline now looks correct instead of that nose down dragster look, even the sitting position in the drivers seat now feels so much better.
    I unfortunately was too busy to photograph before the springs were fitted but compare these to your own. I will check tomorrow how much I can supply & fit these for if anyone is interested, but if you have been thinking about it, GET IT DONE.
    [​IMG]
    [​IMG]
    [​IMG]
  16. Techno
    Jul 28, 2010
    14,189
    15,163
    Are you on 15 or 16" wheels?
  17. cj440
    cj440 Trader
    Sep 19, 2013
    16
    5
    sunny fife
    16" :Eeek: They now look like 15" in the pictures lol.
    CJ.
  18. Techno
    Jul 28, 2010
    14,189
    15,163
    Yes I'm very interested :thumb: LMK
  19. cj440
    cj440 Trader
    Sep 19, 2013
    16
    5
    sunny fife
    I found this image from last week,
    [​IMG]
    CJ.
  20. cj440
    cj440 Trader
    Sep 19, 2013
    16
    5
    sunny fife
    Hi Guys, for anyone interested heres some photos of a 2.8jtd Ducato with the uprated front coil springs fitted. You can clearly see the difference in looks but the driving is again transformed. Much more compliance & far less body roll. This is a no brainer.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Anyone want more info just let me know,
    CJ.
Similar Threads
  1. Daveg
    9
    173
  2. rogher
    42
    1,524
  3. Louis
    64
    2,989
  4. JWF1
    16
    772
  5. enery8
    3
    338
