Ducato Diesel Filter - water warning light
Discussion in 'The Beginner' started by jimothy, Apr 22, 2012.
  1. jimothy
    jimothy Read Only Funster
    Apr 12, 2012
    205
    78
    Andover
    The water-in-filter warning light is on on my dash.
    Well, it starts off on (and doesn't go out after engine starts), but then after driving a bit it does go out, and then amusingly it flashes in antiphase with the indicators when they're going.
    The engine is running lovely - fires up immediately and runs smoothly, and I've read on the internet that the water sensor can be a bit temperamental. So should I just ignore it as it's probably just being daft?
    I've also read that the filter might have a drain plug on it, so I was thinking that it might be worth just draining off any water in case it is present? In which case, can anyone tell me how to do it?
    I *think* I've found the filter - lurking behind the air filter bucket; grey cylinder, it does have what looks like a plastic wheel on the bottom of it... but didn't want to go unscrewing things without being sure.
    It's a 1997 vintage, 2.5 TD.
    Thanks for help and advice as ever :BigGrin:
  2. 656
    656 Read Only Funster
    Jul 30, 2007
    1,150
    291
    The universe
    The "wheel" will either be the drain tap or the screw that holds the filter bowl on. Why not get a replacement filter and change it? They are only a few quid from your local parts dealer!
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    thats the water drain screw.
    unscrew slowly untill water/fuel runs out.
    ideally you need a cup/jamjar underneath to catch the waste fuel...half a cup should clear it of water.
  4. ciderman
    ciderman Funster
    Jul 2, 2011
    359
    409
    derbyshire
    with the light going on and off with the indicators i would check for any earthing issues
