Ducato bonnet lock (1 Viewer)
Steve
1,613
2,062
Compton Berkshire
C class
on and off for 40 years
Does anyone know of a good external bonnet lock that will fit my 2004 Ducato.
Steve
43,301
49,287
Easily modified for a bonnet....
Or a neater solution....
Jan 28, 2008
10,111
18,365
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
you could use bonnet pins rally car style and put a padlock though the hole instead of a pin
Steve
Steve
1,613
2,062
Compton Berkshire
C class
Because it is easy to open from outside if you know how to.Broken Link Removed:rolleyes:
And to get to the release from the inside would take all of 5 secs. I want to put a battery isolation switch with low amp bypass on it but not much good if the bonnet can be opened so easily.
TerryL
6,171
8,174
North East
Low Profile
Fair enough. It occurs to me however that your, I presume, anti-theft device would not really be apparent to any passing tealeaf who would not spend time trying to find out why it wouldn't start.
DanielFord
3,020
3,086
I could strip your engine down to it's component parts from the underneath in about 2 hours, regardless of whether there was a bonnet lock. Are you perhaps concentrating on the wrong security?
Steve
Steve
1,613
2,062
Compton Berkshire
C class
readly available battery terminal switch. will blow fuse if high current draw ie starting. But easy to bypass if you can open the bonnet with ease.
TheBig1
17,599
43,021
just immobilise the van with a hidden switch breaking the ignition line or diesel pump depending on which van. making things more complicated than needed is unnecessary
