Ducato (2013) locking door with battery disconnected
Discussion in 'Fiat' started by Ridgeway, Feb 16, 2014.
  1. Ridgeway
    Ridgeway Funster
    Mar 10, 2012
    907
    401
    Lausanne
    How do you lock your doors after you've taken your battery out ?
    Once the battery is disconnected the central locking obviously doesn't work and although I can lock the hab door from the inside and the drivers door from the outside with the key, I can't see how I can lock the passenger door :Doh:
    I can only imagine that you need to lock all doors via central locking, disconnect the battery and then climb out through garage:Eeek:
    I am missing something ?
  2. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,807
    1,027
    Cark, Cumbria
    Why not lock the drivers & passengers doors from inside with button on the dash, then remove the battery & come out through the hab door & lock that from outside?
  3. Ridgeway
    Ridgeway Funster
    Mar 10, 2012
    907
    401
    Lausanne
    Because I the hab door is central locking too and can only be locked from the inside with battery out, I love Italian design:Rofl1:
  4. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,189
    15,163
    Leeds the one up North
    Depends on why you are removing the battery?
  5. DP_JAY
    Mar 17, 2010
    1,807
    1,027
    Cark, Cumbria
    Back to plan A then, I take it there is access to the garage from yhe hab area:thumb:
  6. DP_JAY
    Mar 17, 2010
    1,807
    1,027
    Cark, Cumbria
    Back to plan A then,unless you have manual windows, I take it there is access to the garage from the hab area:thumb:
  7. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,782
    10,198
    in theory, you can put a set of jump leads on the terminals under the bonnet, then remove terminals very very carefully from van battery and wrap in insulating tape. remove battery, close doors and lock with central locking before removing jump leads and closing bonnet
    just a theory though and potentially dangerous as the live terminal connector from the van will remain live after disconnecting. if it touches metal you will short it to ground causing sparks and probable damage.
    DONT ATTEMPT THIS IF YOU DONT UNDERSTAND THE RISK YOU ARE TAKING
    Otherwise you need to lock the doors then disconnect the battery and leave through the drivers door and lock it behind you....not easy to do
    • Like it Like it x 1
  8. Ridgeway
    Ridgeway Funster
    Mar 10, 2012
    907
    401
    Lausanne
    Think I'll give the first idea a miss.
    Will have to try and see if the passenger door unlocks when I unlock the drivers door but no reason it should once the battery is out, this would be the easiest way:thumb:
  9. Ridgeway
    Ridgeway Funster
    Mar 10, 2012
    907
    401
    Lausanne
    To charge it at home.
    Forgot to disconnect it last time we used it and the lovely Fiat Canbus system vaporized the power in the battery...
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    once more modern technology comes to the forefront of stupidity.
    why is there no allowance for locking the passenger door from the inside or outside when power is removed.
    it was never a problem before the computer age fitting an internal door lock button.
    unfortunately this ridiculous technological march forward will never end.
  11. Ridgeway
    Ridgeway Funster
    Mar 10, 2012
    907
    401
    Lausanne
    Fully agree, couldn't believe there is no key hole on the passenger door, there's a lock but no key hole ! Must have saved a fortune on the design there…..
    And the Canbus is simply ridiculous at draining power.
  12. pappajohn
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    fiat door skins allow fitting of new keyholes in 3 seconds with nothing more than a screwdriver.
    if they spent as much upgrading there materials as they do on electronics they would have a better product.
    my last ducato had the pasenger lock screwdrivered....once i took out the lock i straightened the metal round the hole with my finger and thumb.....nowt more than thick tinfoil.
  13. Ridgeway
    Ridgeway Funster
    Mar 10, 2012
    907
    401
    Lausanne
    Thinking about this, it can't be that difficult to replace the existing handle with one that has a key hole in it, and then replace the lock barrel.
    Will look into that.
  14. TheBig1
    Nov 27, 2011
    7,782
    10,198
    just order the opposite of your van....for a lhd van buy rhd drivers door lock:thumb:
    mind you ive not looked at the van but my rhd nissan has a (hidden) keyhole on the near side door only and lhd its the same door. a real pain in the bum if the battery in the key fails. i have to unlock passenger door get in, lean over and unlock then go round the other side to get in and drive
  15. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    I have to park with the drivers side up against a house so cannot get at the door I have no rear doors and the passenger door and the sliding door has no keyhole? whoever thought of that :Doh: you have to open the passenger door to get at the battery jump point :Doh:
    if my battery ever goes flat I will never get in the van through any doors and of course they will be deadlocked:Eeek:
  16. TheBig1
    Nov 27, 2011
    7,782
    10,198
  17. SandJ
    SandJ Funster
    Sep 14, 2007
    1,595
    558
    North Yorks
  18. Ridgeway
    Ridgeway Funster
    Mar 10, 2012
    907
    401
    Lausanne
    Will have a look this evening but that would be a workable solution better than yesterdays palaver
  19. SandJ
    SandJ Funster
    Sep 14, 2007
    1,595
    558
    North Yorks
    That was from Fiat a few years back :thumb:
  20. Ridgeway
    Ridgeway Funster
    Mar 10, 2012
    907
    401
    Lausanne
    Well just checked and it's still there and works as you describe.
    The hole is on the inside of the door although hidden once it's closed. It's just above the lock mechanism and is around 10mm OD. My engine key wouldn't fit in mine so I gently used the garage key and this worked fine. A small click and then close the door and it's locked :BigGrin:
    :thumb:
Similar Threads
  1. SandraL
    111
  2. rogher
    42
    1,523
  3. Louis
    64
    2,989
  4. JWF1
    16
    770
  5. rutteger
    5
    610
