Ducato 2007 engine management and airbag warning lights
Discussion in 'Tech/Mech General' started by oggie, Aug 4, 2014.
  1. oggie
    oggie Read Only Funster
    Mar 25, 2014
    30
    34
    cheshire
    Hi all, considering a private purchase of a Ducato 2007 model, but have noticed the air bag warning plus engine management warning lights are on. present owner changed the passenger seat and said the warning lights came on then.
    My concerns are
    1. does the engine management symbol come on with the air bag fault light?
    2. is an DIY reset feasable.
    The van itself is in brilliant condition, drives well, (reverse gear judders a bit) the owner seems to be genuine but would just like to check these faults before committing.
    Any advise would be appreciated
  2. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,366
    9,811
    sounds very much like the owner that changed the passenger seat didnt plug the wiring back in. if it was to change a double seat to a single, the system cant find the missing seatbelt. it needs to be rewired and is not a DIY job for most people. will also be an mot fail due to the fault light
  3. chaser
    chaser Funster
    Feb 16, 2013
    7,302
    7,996
    uttoxeter
    Shouldn't do, unless it's just a general light for anything, changing the front seat can do the airbag light and although not DIY is easy enough to put off providing that is the only thing putting it on, but it needs checking as it won't pass mot with it on and if it is something else can be very dear to fix
  4. TerryL
    TerryL Funster
    Mar 5, 2010
    1,361
    1,338
    North East
    If you are serious about this particular van why not suggest the seller gets it fixed before you complete. Then you'll see how 'genuine' he is.
    Engine warning light should have nothing to do with the airbag light so there's probably something else - and that's a complete new thread (search engine management fault warning).
  5. MikeD
    MikeD Funster
    Dec 21, 2011
    2,052
    1,827
    London
    It really needs to be plugged in to a diagnostic computer.
    "Engine" and warning lights come on for lots of reasons, some easy fixes some not so.
  6. oggie
    Mar 25, 2014
    30
    34
    cheshire
    Thanks guys will be careful
  7. TheBig1
    Nov 27, 2011
    7,366
    9,811
    if you are thinking about doing it yourself.....remember to disconnect the battery first. if you dont, it could easily trigger the airbags if you get it wrong. expensive, messy and painful if they hit you
  8. Bobby22
    Bobby22 Funster
    Dec 15, 2013
    1,102
    3,426
    Scotland
    I would suspect the guy is telling the truth, we had a citroen relay and the seat plug disengaged. Plugged it back in and the light extingquished. The light also alerts to seatbelt pre-tensioners.
    I read a bit on SBMCC that you can fit a capacitor or something to get your problem solved.
    This may not help OP but someone else can benifit i hope.
  9. Zains Pops
    Zains Pops Funster
    Sep 10, 2013
    723
    4,154
    Chelmsford Essex
    Seat belt lights are an MOT fail, recently had to scrap the wife's Honda as the ABS light caused a fail and the cost to diagnose and repair too high for the cars and our regular garage didn't want the job as it could easily turn into a real can or worms, so we part exd it for a new one. Pity really as the basic car was good in all other aspects other than being 16years old!!
    Be careful and have the present owner fix the problem with a trusted garage before parting with your hard earned..
