Ducato 1994 sudden wobble/Vibration (1 Viewer)
Issie52
13
6
Yorkshire
Fiat Ducato Rivera. 1995.
Our ducato MH has suddenly developed a wobble? Not all these time just now and again?
It's a definite vibrate
Checked the drive shaft, but thats tight and no movement. CV joints OK. Checked rubber boots OK, one circlip a bit lose
Set off again and after a while it's wobbling vibtating again?
Done 1500 kms in the last week driving through France and now into Spain without any problems
Anyone any ideas what it can be?
Minxy
32,646
66,530
E Yorks
Carthago Compactline
Check the wheels are on correctly and all nuts tight as this can cause wobble. Other than that it could be tracking, or a wheel balance weight has gone astray which will cause 'wobble' only at certain speeds, this to me is the most obviously cause.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Also, check for an inside bulge on one of your front tyres. You might not see it at first, if any bulge is against the road. Also, the early Ducato's got through track rod ends at an alarming speed, changed one of mine twice now.
Issie52
Issie52
13
6
Yorkshire
Ours has got two new track rod ends. Tyres look OK
But will take them off and have a look
Thank you
Good job we are on a nice site here
Issie52
Issie52
13
6
Yorkshire
Right hand side tyre looks to have a problem inside ! Taken it off and put spare on, let's hope this was the problem !!!!will let you know when we set off tomorrow.
Thank you all
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
A worn wheel bearing can cause the wheel nuts to loosen unevenly. A steadily increasing rhythmic hum is one symptom.
When ours started to go on a trip to Europe I was tightening the old nuts (ooer missus) at every stop on the journey, until we got home.
Issie52
Issie52
13
6
Yorkshire
No noplay in wheel bearing. It has just passed its French mot. Hubby says all tyres are OK taken them all off and checked.
It vibrates. When you get to 80 kms !
he says only thing is just a slight movement on drive shaft, only a little bit, so it has got us stumped?
Off for a test drive tomorrow up to Salou, if we have the same problem we will have to find a site there and stop over.... Any good sites there that are open now? Just in case ..
Minxy
32,646
66,530
E Yorks
Thank you all
How old are your tyres?
Steve
1,613
2,062
Compton Berkshire
C class
on and off for 40 years
it happans with speed? maybe as simple as a wheel weight has come off and they need to be rebalanced
Issie52
Issie52
13
6
Yorkshire
Just tootling along at 80 kms and then vibrations from right hand side! When we slowed down it stopped ? We hit a bad patch of road a few km back. Well we will tell you tomorrow ! Off back up to Salou instead of going south!
R
Robert Clark
Worth checking wheel balancing and alignment
Weight can fall off and alignment can go out if you hit a pot hole
Issie52
Issie52
13
6
Yorkshire
Just to let every one know what the problem was with our Ducato MH
It was the shock absorber on the right hand side!
Replacing them this week
Tyres were ok.
Issie52
Issie52
13
6
Yorkshire
Still trying to source Stock Absorber in Spain, Norauto do not sell them for Vans! only cars!(n)(n)
Minxy
32,646
66,530
E Yorks
Why not go to a normal garage and see if they can get one for you?
