Dual Gaslow system or Fit Permanent Vapour Tank.
Discussion in 'Tech/Mech General' started by American Dream, Aug 2, 2009.
  1. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Hi All,
    I have a dilemma.
    Replace the long "torpedo" shaped LPG tank that feeds all the appliances (Warm Air/Hot Water/Oven and Fridge) or go down the Gaslow route.
    The Gaslow's would be arranged as a pair.
    Can you get level meters (remote) for them ?Does the t connector have to have a non-return valve in it?Do they do an auto changeover?
    Many thanks for any Pros and Cons you might have.:thumb:
    Steve.
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,265
    5,250
    East Sussex 01-580-881288
    Replace the tank would be cheaper I would think even though I have a vested interest being a Gaslow stockist:cry:
    Peter
  3. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Cheers Peter...But would it be my best option?Are there benefits going the gaslow route?I was thinking of removing the on-board genny and utilising the space for the bottles.
    A 40 litre vapour tank is approx £250 +vat and del?
    Do american RV's require a different gas pressure Reg?
  4. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,855
    roche cornwall
    hi, its usually possible to fit any type of regulator to the tank. look on your cooker or something there is probably a sticker stating the working pressure. i prefer to fill my own bottles .cant see the cost of gaslow to be an advantage.you would still need the correct regulator to use them. alan
  5. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Cheers Alan.
    Looks like it'll be a replacement under the chassis then.
  6. Blisters
    Blisters Read Only Funster
    Apr 2, 2008
    597
    3
    Stoke on Trent
    I would proberbly go down the under slung tank, (can you not fit something a little bigger say 60 ltr - Gaslow would give 44ltr)
    I had the same dilema and went the other way and have had problems with the gaslow leaking as a result of vibrating whilst driving.
    The other advantage of a vapour tank is you will free up space for storage
  7. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Cheers Blisters...
    Didn't realise there could be problems with the Gaslows.
    Do you disconnect yours to fill?
    I was looking for a "permanently" plumbed is solution with them.
  8. The Wild Ones
    The Wild Ones Read Only Funster
    Jan 4, 2009
    76
    Oxfordshire
    My next project is to add either a permanent LPG tank or a pair of Gaslows. The advantage I can see with the latter is being able to transfer them easily to a new mobee when the time comes.
