Drl lights
Discussion in 'Tech/Mech General' started by Mark5204, Jan 25, 2015.
  1. Mark5204
    Mark5204 Funster
    Jan 20, 2015
    229
    60
    Bristol
    Hi. I have a set of DRL lights I am thinking of putting on to my 54 reg ducato. They don't come with relays etc. Does anyone know if it will cause problems when connecting to hook up. Is there a way around it if so?
  2. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,686
    11,802
    Plympton, Devon
  3. Mark5204
    Mark5204 Funster
    Jan 20, 2015
    229
    60
    Bristol
    Great Thank-you. Was a little bit concerned as I have read on here about problems when hooking up to mains etc.
  4. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,182
    14,954
    Leeds the one up North
    I don't understand what DRL's have got to do with being on hook up?
    DRL's should only work when you are driving, how long is your lead?
  5. Mark5204
    Mark5204 Funster
    Jan 20, 2015
    229
    60
    Bristol
    I agree but I have read it on this site and being new to MH wanted to check.
    I have Googled and there are supposedly special DRL KITS to avoid the issue.
  6. Techno
    Jul 28, 2010
    14,182
    14,954
  7. Mark5204
    Mark5204 Funster
    Jan 20, 2015
    229
    60
    Bristol
    I was reading a post on Drl lights
  8. Techno
    Jul 28, 2010
    14,182
    14,954
    Surely it would have been better to continue in the thread where you read that? Unless you can find it I cannot comment
  9. Techno
    Jul 28, 2010
    14,182
    14,954
  10. Mark5204
    Mark5204 Funster
    Jan 20, 2015
    229
    60
    Bristol
    it's in a post that you were part of I don't know how to copy link but if you look in tech section under Day running lights. Page 2 it's mentioned there
  11. Mark5204
    Mark5204 Funster
    Jan 20, 2015
    229
    60
    Bristol
  12. Mark5204
    Mark5204 Funster
    Jan 20, 2015
    229
    60
    Bristol
    That's what got me wondering. Your lights look good
  13. Techno
    Jul 28, 2010
    14,182
    14,954
    I've never heard of that and certainly the instructions with mine never said anything but then again if they are wired to the instructions which would be an ignition switch feed AND a permanent feed (to the control unit) as well as a negative connection and a headlight connection. I can't imagine how they can be brought on by mains to the habitation.
    • Like Like x 1
  14. Techno
    Jul 28, 2010
    14,182
    14,954
    The permanent feed allows the DRL to stay lit for a period after switching the ignition off. The ignition switched feed powers the lights at full brightness and the headlight connection tells the controller to dim the DRL when headlights are on.
    • Like Like x 1
  15. Mark5204
    Mark5204 Funster
    Jan 20, 2015
    229
    60
    Bristol
    The ones I have got here don't have a controller or anything so either going to wait and buy a better set or give these to a mechanic friend of mine to wire up.
  16. Wickolad
    Wickolad Funster
    Sep 10, 2013
    480
    518
    Wickersley
    I think there may have been a misunderstanding and that the OP meant there may be problems when connecting, using 'hook up' as a phrase for adding power to the lights. Problems he mentions may be those discussed for Canbus system.
  17. Wickolad
    Wickolad Funster
    Sep 10, 2013
    480
    518
    Wickersley
    Hi Mark, I think you just need a DRL relay, usually have to buy them seperate. The instructions that come with the relay are self explanatory, however, the excellent thread by Techno mentioned above will fully explain all.
    • Like Like x 1
  18. Mark5204
    Mark5204 Funster
    Jan 20, 2015
    229
    60
    Bristol
    Thank you for your reply. Will look for a relay. Very helpful.
  19. Wickolad
    Wickolad Funster
    Sep 10, 2013
    480
    518
    Wickersley
    • Like Like x 1
  20. Mark5204
    Mark5204 Funster
    Jan 20, 2015
    229
    60
    Bristol
    Thank-you.
