DRL Lights
Discussion in 'The Beginner' started by Mark5204, Jan 22, 2015.
  1. Mark5204
    Mark5204 Funster
    Jan 20, 2015
    229
    60
    Bristol
    First job on our New MH over the weekend. Fitting some drl lights.
  2. RS_rob
    RS_rob Funster
    Dec 14, 2013
    885
    605
    Turnford
    Ring Aurora they are excellent & come with everything you need including a totally automatic box of electrics.
    • Like Like x 1
  3. RS_rob
    RS_rob Funster
    Dec 14, 2013
    885
    605
    Turnford
  4. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    2,983
    7,229
    Market Harborough
    Offend wondered about the benefits of fitting DRL I know there brighter but wouldn't it just be easier to turn on your dipped headlights? (y)
    • Like Like x 1
  5. RS_rob
    RS_rob Funster
    Dec 14, 2013
    885
    605
    Turnford
    DRLs are very bright white light much more so than your standard fitted lights making you much more visible in the daylight hours over normal lights.
    it's now law that new built cars have to have them.
    it's not required to retrofit them tho.
    • Like Like x 1
  6. RowleyBirkinQC
    RowleyBirkinQC Funster
    Sep 20, 2014
    663
    1,346
    Dazed & Confused
    Many motorhomes are quite large white boxes on wheels, how much more visible do you need to be? ;)
    • Like Like x 4
  7. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,541
    2,548
    Trowbridge
    And fitting unfiltered led lights pointing directly into the eyes of oncoming vehicles makes no sense to me. I'm continually annoyed and frequently caused to slow down because I can't see properly. We need to have a lights test like some continental countries and plod need to get better at dealing with badly lit vehicles.
    If you are fitting them, please make sure they go off when it's dark at the very least..
  8. Landy lover
    Landy lover Funster
    Jul 11, 2009
    2,036
    3,886
    Zummerzet
    The law requires that when headlights are turned on they must be of reduced power NOT turned off. Anyone fitting them should buy a small box of tricks that does that exactly that. There are lots of cheap kits out there but they scatter light not direct light. Worth spending out on a kit from a reputable manufacturer such as this http://www.ebay.co.uk/itm/PHILIPS-D...arts_Vehicles_CarParts_SM&hash=item3a95ddfb46 which includes all the relays and controls.
  9. Mark5204
    Mark5204 Funster
    Jan 20, 2015
    229
    60
    Bristol
    • Like Like x 1
  10. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    4,811
    9,035
    Lorca,Murcia,Spain
    I thought that but the actual law is new MODELS. Any model started building before the legislation doesn't have to be fitted with them.
  11. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,107
    14,921
    Leeds the one up North
    [​IMG]
  12. hilldweller
    Dec 5, 2008
    26,920
    25,766
    Macclesfield
    Which means oncoming drivers' eyes are "pulled" to your vehicle and away from the cyclist they are about to run over.
    I think these things are a serious error and time will show reduced car bumps and increased cyclist/pedestrian accidents.
    • Like Like x 1
  13. EssexBoy
    EssexBoy Funster
    Feb 5, 2009
    325
    212
    South Essex
    I agree. I'm completely fed up with car/van drivers that have a headlight adjuster on their dashboard but just don't use it, preferring to blind all those with the temerity to drive either in front or behind them :cautious:(n):cautious::cautious::cautious::cautious:
    • Like Like x 1
  14. wingman
    wingman Funster
    Feb 10, 2013
    986
    2,492
    Romford, Essex
    I'd be interested to know if these are compatible with CanBus wiring systems?
  15. Techno
    Jul 28, 2010
    14,107
    14,921
    Yes
    Also as you can see in my picture above they DO NOT dazzle. They are full brightness at dusk and would not photograph if they did.
    X250 connections. plus one to earth and one to headlight harness.
    [​IMG]
    A daylight picture
    [​IMG]
  16. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,541
    2,548
    Trowbridge
    Damn.. because of that photo I just ran over a small child that was playing in the road...
    Seriously though, they look grand. They will help with being seen, will reflect off damp roads and ice giving possibly more warning than without them on a winter's morning and... Most importantly .. are down low enough not to dazzle most oncoming motorists.
    I was harsh before but I genuinly feel more enforcement is required around lighting. Crap design of modern cars, crap maintenance of new and older vehicles and badly thought out vanity modifications make driving at dusk or night lethal and the trend for DRLs is stretching that into dull days as well.. I suffer badly with dazzle at night to the point where I have had tests done on the light sensitivity of my eyes. These came up as normal (probably the only part of me that is) so others must suffer as badly as me.
    • Like Like x 2
