Driving licence on reaching 70years
Discussion in 'Motorhome Chat' started by lookback, Mar 19, 2010.
  1. lookback
    lookback Read Only Funster
    Nov 30, 2007
    142
    25
    Mareham le fen, Lincs
    I am going to reach the age of 70 years in Nov this year and just received this e.mail from the DVLA:
    "At the age of 70 if you do not apply to retain the heavier categories your licence will show the following categories.
    B = motor cars or light vans up to 3.5 tonnes with up to 8 passenger seats.
    B+E = motor cars and light vans up tp 3.5 tonnes pulling a trailer over 750kgs.
    Therefore provided the motorhome and vehicle you intend to tow fall within the above category your licence will be sufficient"
    Hope this clarifies the subject.
    Ian
  2. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,755
    3,254
    Eastbourne East Sussex
    Looks like you could run a 5th wheeler on that, as long as the tractor was under 3500kg. There doesn't appear to be a weight limit on the trailer part, or have I got it wrong?:Blush:
  3. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,468
    881
    South Glos
    Not quite, the weight of the trailer that can be towed depends on the unladen weight of the towing vehicle.
    The DVLA site says "The weight of the trailer, when fully loaded, can’t weigh more than the unladen weight of the vehicle"
  4. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,684
    13,234
    Norfolk
    I believe that the application to retain your current licence groups depends upon a positive medical checkup. As far as I know no other test i.e. driving or theory is required
  5. pudseykeith
    pudseykeith Read Only Funster
    Nov 5, 2007
    382
    105
    Leeds West Riding of York
    70 + licence
    Hi All. If your rig is over 3.5 ton you must apply for a heavy goods licence. If you don't they will send you a car licence If i remember rightly, you also have to request an additional form and medical document for your GP to fill in. The only down side is the cost of the medical, ouch.
    Pudseykeith. :thumb:
  6. Jackomet
    Jackomet Read Only Funster
    Nov 10, 2008
    293
    65
    East Sussex, Europe
    "Not quite, the weight of the trailer that can be towed depends on the unladen weight of the towing vehicle.
    Not, not quite
    Does not mean 5th wheels, or there would be a lot of people like me with a 2.2 ton Navara pulling a 3.6 ton 5er being stopped. Also all HGV drivers are in trouble?
    JK
  7. lebesset
    lebesset Read Only Funster
    May 31, 2009
    760
    good point there ..is the 5th wheel outfit a trailer ? if it is , must not exceed the tuggers weight
    but if it is not it must be part of the total outfit , so would have to be included in the GVW of the tug for licence purposes
    is this clarified anywhere in the regulations?
    if you look at hgv artics they have not only individual weights for the component parts , including axle weights , but also a maximum for the whole oufit
    is this another toad grey area ?
  8. scotjimland
    Jul 25, 2007
    28,936
    25,589
    No, it's not a grey area, Semi trailers or artics have different regulations.
    Factor to determine Maximum Authorised weight - Rigids, Tractors, Trailers & Articulated Vehicles
  9. lunarman
    Sep 23, 2008
    1,468
    881
    South Glos
    The category I quoted was B which is what drivers who qualified after 1/1/1997 received as a right. To drive a combination with a larger trailer you need B+E for which presumably an additional test applies.
    Do they take away the +E entitlement at 70?
  10. lebesset
    May 31, 2009
    760
    lunarman , you keep your B+E licence , or at least I did
    jim , interesting site thank you; according to this section
    http://www.wheelbase.net/legislation-help-desk/drivers-hours.html
    a semi-trailer is a trailer , so you will have to keep within the tractor unit unladen weight for the laden weight of the trailer ; presumably that is why they don't quote a maximum weight for the trailer on the B+E licence ...it will be defined by the tractor as stated
  11. lunarman
    Sep 23, 2008
    1,468
    881
    South Glos
    AS I read it, for driver licensing purposes, as long as you have B+E you can tow a trailer heavier than the MAM of the towing vehicle.
    However I believe that the total weight of the vehicle + trailer should not exceed the specified gross train weight (GTW) of the vehicle. Thus as long as the GTW of the Navara exceeds 5.8 tons then the example is within the rules and can be driven by someone with B+E classification.
    Of course this is only my interpretation and might be completely wrong :Eeek:
  12. lebesset
    May 31, 2009
    760
    lunarman ,can I refer you to your previous quote from the dvla ?
    the laden weight of the trailer cannot exceed the unladen weight of the towing vehicle
  13. lebesset
    May 31, 2009
    760
  14. lunarman
    Sep 23, 2008
    1,468
    881
    South Glos
    I agree with that. The bit about the trailer not exceeding the unladen weight of the towing vehicle is appropriate for category B licences only
  15. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,706
    17,323
    YO11 2BD
    at age 70 you will lose your C1+E entitlement unless you take and pass a medical.
    pre '97 test and you have C1+E as 'grandfather' rights and allows combinations up to 8250kg.
    if your van is under 3500kg and you dont intend upgrading it above then dont bother with the C1+E part.
    B+E will allow a 5th wheel trailer within weight limits, dont know what they are, though it could be the tugs train weight.
  16. pappajohn
    Aug 26, 2007
    29,706
    17,323
    YO11 2BD
    an example would be a rangerover vogue 3.6ltr.
    gross weight of 3200kg
    kerb weight of 2717kg
    trailer weight limit 3500kg
  17. ingram
    ingram Read Only Funster
    Aug 9, 2008
    87
    No you don't need a heavy goods licence; you just need to apply to retain your C1 entitlement; assuming that you have that already of course.
    You don't have to use your GP for a medical: well I don't for the annual medical to retain my Bus Driving ( D ) Licence. It costs me about £50 from the likes of:--
    http://www.driversmedicals.com/_Locations.html or:--
    http://www.doctorsonwheels.co.uk/1.html
    Harvey
  18. lunarman
    Sep 23, 2008
    1,468
    881
    South Glos
    The attachment shows the weights for a new 2.5 navarra. The Train weight looks like it is 5805kg (PTW + Towing weight)
    Assuming that you can offset the payload against the additional weight of the 5er then the maximum weight the vehicle can be is 5805 - 3600 = 2205kg The quoted kerb weight of the vehicle is 2171kg thus the payload that can be carried in the vehicle when towing is reduced to 2205 - 2171 = 34kg
    If I'm right then it is just within the limits:thumb:
    Edit - just looked at the Nissan site the Kerb weight is without the driver so the combination may not be within limits
    [​IMG]
