Drive away awning - am I missing something?
Discussion in 'Tech/Mech General' started by Janine, Apr 3, 2011.
  1. Janine
    Janine Funster Life Member
    Aug 22, 2007
    5,027
    8,159
    Sunny Shropshire
    I've now got a drive-away awning and tried it out for the first time this weekend.
    It went up very easily and is perfect for sheltering from the wind and rain :BigGrin:
    The valance feeds into the channel on the front of the wind-out Fiamma awning but how do you then drive away from it??? (Short of driving away while someone holds the awning in place!!)
    There are also straps to chuck over the roof of the 'van, which are obviously the best method to use if you want to leave the awning in place, but I'm wondering whether I'm missing something here...
  2. nomadic
    nomadic Funster
    Sep 27, 2007
    682
    182
    Shropshire based
    Hi Janine,
    What is the make and model of your drive away awning?
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    Hi Janine,
    what you need is a figure 8 connector and joint tape
    basically two C shaped tubes connected back to back, one side fits onto the 'valance', the other side fits onto the joiner tape, which is a narrow fabric strip with a bead on both edges.
    the other side of the joiner tape slides into the awning rail. (as its nylon fabric it can be left in situ)
    when you wish to drive away, simply remove the figure 8 strip and drive away.
    tip!!!
    place a couple of flattened drink cans behind a front and rear wheel before driving away.
    when you return simply drive over the cans and you're aligned back in the same position to reconnect the awning.
    the bit in the pic which is connected to the gutter actually slides into the joiner srtrip. [​IMG]
    • Like it Like it x 1
  4. Janine
    Aug 22, 2007
    5,027
    8,159
    Sunny Shropshire
    Oops..yes..that would be useful...
    It's a Riviera Mobil 300
  5. blamehofman
    blamehofman Read Only Funster
    Oct 31, 2010
    561
    502
    Northumberland
    Got the same awning and the figure 8 strips work a treat .
  6. Janine
    Aug 22, 2007
    5,027
    8,159
    Sunny Shropshire
    Thank you everyone - will have a google for the figure 8 strip :BigGrin:
  7. dshague
    dshague Funster
    Aug 22, 2007
    919
    188
    sth yorks
  8. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,396
    5,424
    East Sussex 01-580-881288
  9. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    Janine is this any use to you
    [ame]http://www.youtube.com/watch?v=1yVH5H3eLd4&feature=player_embedded[/ame]
  10. Bailey58
    Bailey58 Funster Life Member
    Jun 23, 2010
    6,670
    10,348
    Norfolk and Toftir.
  11. Jaygee32
    Jaygee32 Read Only Funster
    Oct 9, 2009
    152
    14
    Norfolk
    I wouldn't leave flattened cans.....some tidy person will pick them up and bin them!:Rofl1:
  12. dellwood33
    dellwood33 Read Only Funster
    Apr 25, 2009
    3,449
    887
    Newcastle
    If ramps were required to get the van level, would you leave them in position for your return ? or do you think someone would "Tidy" them up when you were away :BigGrin:
  13. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,665
    14,460
    North Lincolnshire
    We have one of those.
    Works fine with the throw overs secured to plate lifters (Handle type sucker things) stuck to the far side of the van.
  14. pappajohn
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    good point...most certainly they'd go walkabout....maybe a tent peg or two with a bit of ribbon attached then.
    as above
    i found the same when i had mine...much higher than the awning rail so the door didnt drag across the fabric so much.
  15. dellwood33
    Apr 25, 2009
    3,449
    887
    Newcastle
    I think the throw over fittings would block the solar panels on mine :Smile:
  16. pappajohn
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    never had a problem with mine...one strap over the panel.
    not a lot different to a shadow from a branch etc :thumb:
  17. bellabee
    bellabee Funster
    May 8, 2010
    615
    796
    Staffs/Shropshire border
    Hi Janine. We got some figure of 8 strip and webbing at Salop Leisure, last week. Have yet to try out our awning (except on the drive).
  18. pappajohn
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    just had a thought !
    there are two sizes of joiner strip....4mm and 7mm i think.
    i bought the larger without realising and it wouldnt fit in the awning rail slot.....but it does fit in the figure 8.
    best to measure across the end of the slot before buying.
  19. dshague
    dshague Funster
    Aug 22, 2007
    919
    188
    sth yorks
    the F45 Takes the 6mm and the new f65 takes 4mm .
  20. harryoxford2
    harryoxford2 Read Only Funster
    Sep 14, 2010
    559
    255
    Bishops Stortford Herts
    I had a drive away awning once, i errected it and went into my van for a cuppa and when I came out it was gone..it had driven away....so make sure ya peg em down good and hard as the iccle tinkers are sneaky...
