Dripping Tap
Discussion in 'Introduce Yourself' started by ralph304, Mar 28, 2010.
  1. ralph304
    ralph304 Read Only Funster
    Mar 28, 2010
    Hi i have a ci mizar gtl living and i have just been checking the motorhome for the new season and found that the tap in the sink in the toilet is dripping Does anyone have any idea what the cause may be thanks.
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,259
    5,240
    East Sussex 01-580-881288
    Try turning it on and off a few times, could be lack of use hopefully
    Peter
  3. dshague
    dshague Funster
    Aug 22, 2007
    910
    184
    sth yorks
    how old is your van ? you can buy repair kits for some makes of taps .
    did you leve your taps closed over the winter ?
  4. bald eagle
    bald eagle Read Only Funster
    Jan 30, 2009
    528
    4
    here,there and everywhere
    How ralph304
    it looks like it could be a washer.
    Best of luck:thumb:
    regards
    bald eagle:thumb:
  5. Doodlebug
    Doodlebug Read Only Funster
    Jan 28, 2010
    140
    Surrey
    Hi and welcome.
    :BigGrin::BigGrin::BigGrin:
  6. ralph304
    Mar 28, 2010
    Hi it is a 2006 model. Yes i closed the the taps over the winter.thanks
  7. imprint
    imprint Read Only Funster
    Jul 14, 2009
    1,090
    11
    Q. " Does anyone have any idea what the cause may be?"
    A. Water.
    Welcome to the Fun Farm, Ralph. Bet you before we're through answering, or at least trying to be helpful, supporting you in your misery, or at least showing what caring folk we are, someone will suggest a cure for water on the brain...
  8. Spacerunner
    Spacerunner Read Only Funster
    Apr 7, 2008
    609
    195
    Hampshire
    Could be frost damage.....always leave taps open when laid up over winter :Doh:
  9. dshague
    dshague Funster
    Aug 22, 2007
    910
    184
    sth yorks
    yes it could be frost damage.frost will blow the rubber seals in the tap .
    look on caravan parts on line to see the make of tap ,then see if you can buy a repair kit ,that's if you want do do it your self .a tap can cost £30 TO £50 to buy plus labor if dealer changes tap.
    i have domietic single lever taps in our van they make a internal value assembly cost £10.
    if you have wale taps they also have a kit .:thumb:
  10. philw111
    philw111 Funster
    Mar 22, 2009
    602
    509
    Moray Firth
    I had the same problem (with two taps:Doh:) last winter. I bought two inserts through eBay from caravanstuff4u and found the service and price very good. I think I paid about £15 each which is a lot cheaper than new taps. Search for "tap inserts" and check dimensions given against your old ones - I bought "Reich" inserts even though I don't have Reich taps but they fit perfectly.
    Phil
Similar Threads
  1. Fred Bertram
    6
    191
