Drip Requires Condensation Advice
Discussion in 'Tech/Mech General' started by Tootles, Nov 10, 2013.
  1. Tootles
    Tootles Funster
    Sep 14, 2013
    9,102
    32,022
    Lancaster
    The only condensation I seem to be getting on cold mornings with the Hymer, is from the sloping front window over the luton. Seems a bit amateurish to just bung a towel there, and so has anyone developed a simple method to either stop the conden happening in the first place, or to catch said drips??
    Ta. :thumb:
  2. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,615
    2,189
    Rutland
    The secret to getting rid of condensation is better air circulation.
    Blown air heating or a fan,even just a few windows open on the first clasp.
    Vlad
  3. Tootles
    Tootles Funster
    Sep 14, 2013
    9,102
    32,022
    Lancaster
    Done all that Vlad, and it works on all the other windows, However, it's just that one very high window, and I think only because it slopes, causing more of a problem.
  4. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    hot air rises so thats probably where its hitting the cold window. perhaps some form of extra insulation on that window. prob have to be on the outside like a mini silver screen:Doh:
    • Like Like x 1
  5. Mousy
    Mousy Funster Life Member
    Sep 13, 2013
    2,138
    7,124
    Sa15 2DG
    Employ a window licking nutter...there is one on here called paddy something :Rofl1:
    • Like Like x 3
  6. themogs
    themogs Funster
    Oct 23, 2012
    838
    881
    Wales
    :Smile:Hi Tootles :BigGrin:
    We only started M/Homing 2 years ago, and had same problem:cry:
    An experienced M/Homer told us to get an EXTERNAL silver screen (preferably the genuine article, with a pull down bit for the daytime:RollEyes:), and it works a treat. NO condensation for us in the mornings now...job done.
    :thumb::thumb:
    • Like Like x 2
  7. Tootles
    Tootles Funster
    Sep 14, 2013
    9,102
    32,022
    Lancaster
    Thanks for that. How do you get to it, to fit the screen? I would need at least a nine foot ladder. Do you use the roof ladder, and walk across the top?
  8. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,327
    34,801
    I think that's the answer to the main windscreen, not Dave's problem.
    You would probably need to make (or have made) a bespoke external screen to fit the window. It could probably be fitted from the inside but would need something to keep it in place - maybe suckers like car windscreen frost covers or elastic fastened to both sides.
  9. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    i think theres cross wires here, moggs was talking about his windscreen i think.
    however, you could try an experiment with extra thick or a few layers of bubble wrap and fit it from the inside ( open window, put insulation on outside of window , secure with some large elacy bands, close window, see what happens. or am i just being silly:Doh: it has been known :Eeek:
  10. Tootles
    Tootles Funster
    Sep 14, 2013
    9,102
    32,022
    Lancaster
    Its a really stupid window, Phill, only accessible from the inside by lying on the luton, and its a fixed panel window, dosent open, however, the bubble wrap has given me an idea, making a fixed inside panel I can secure over it. Thanks again.
    • Like Like x 1
  11. jackrussel
    jackrussel Read Only Funster
    Jul 8, 2012
    54
    47
    south cheshire
    condensation
    You may like to do as I have done, buy a dehumidifier; true, only works on hookup or genny (240v), failing that, one of those crystal filled damp traps, which will use up crystals as a consumable. Could get expensive! Unless you only use them when its cold outside. Silver screen option good if you suss out how to get up to fit and remove it. Can you live with it left on all day- but obviously not on the move. My dehumiddy was bought from ebay, its a dessicant type, and gives warm air out to boot, so offers heat. Bit too warm for late summer cool evenings sometimes...but stays 100% dry inside, however cold out.
    • Like Like x 2
  12. bernardfeay
    bernardfeay Read Only Funster
    Nov 18, 2009
    575
    825
    Bolton
    I never thought I would be the one to solve this. You get a really good sponge and mop it up. In other words you just live with it.
    I know, I know, I should be pitching on Dragon's Den.
    • Like Like x 1
  13. themogs
    themogs Funster
    Oct 23, 2012
    838
    881
    Wales
    We put ours on by using the small step we carry around with us...no problem.:thumb:
    But ours is a Ducato 130 and is easily done....but an Hymer ?? err.. not sure. :Sad:
  14. schojac
    schojac Read Only Funster
    Apr 25, 2009
    339
    234
    Cambridgeshire
    As a first option you may like to try some radistor insulation - the silver sandwiched bubble wrap stuff. Not too expensive and easy to shape; plastic suckers to secure. You could double up the thickness to make more effective.
    I actually use this to make sucure all my windows when stored; keeps prying eyes away and also protects expensive main screens from the sun.
    • Like Like x 2
  15. Tootles
    Tootles Funster
    Sep 14, 2013
    9,102
    32,022
    Lancaster
    Thought about a dehumid, but it would have to be fairly small.......In fact, can you give me the make and model of yours??? I like the warm air option. :thumb:
  16. jackrussel
    Jul 8, 2012
    54
    47
    south cheshire
    dehumidifiers?
    Tootles,, its very similar, but not identical to, this:-
    http://www.ebay.co.uk/itm/POWERFUL-...arden_Hearing_Cooling_Air&hash=item3a63e15de9
    Mine was £169 IIRC, and is dark grey metallic colour. It does indeed do the business. Sometimes, I think the air is too dry, but, if set at a lower setting,(60% RH) does not quite remove it all, 40% may do it- I will be trying that in the next 2 weeks- but I don't have it on during the day, so the air can be quite moisture laden by bedtime. The 'laundry' setting does what it says on the tin, just be aware of the water level in the tank (tho' they autostop when full). Not too noisy either; if you can tolerate a fan, this shouldn't cause a problem. I used it in the house also, and with just as much success. Good kit!
    • Like Like x 1
  17. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    Only really got two choices :BigGrin: board over it or insulate it :BigGrin: if nothings done then it will keep condestating up causing damp problems --try putting a few layers of bubble wrap on it -I simply stuck some thermo/celotex board on ours -did not let light in but stopped condensation -simply took it off come sale time :Wink:
    terry
  18. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,172
    12,517
    goole
    hats wat we used on our last van up in the lotion windows it worked a treat
