Drilling holes through Van to fit extra Awning lighting
Discussion in 'Motorhome Chat' started by JimboT, Sep 6, 2014.
  1. JimboT
    JimboT Funster
    Nov 6, 2013
    245
    167
    Welwyn Garden City
    Ok bought two Fiamma LED awning lights.
    was going to drill and bolt to underside of awning.
    Then run wiring inside awning case drill one hole through awning case + van just above outside light and spur lighting off current outside light.
    This hole and wiring will enter van in front cupboard with TV wiring.
    Have got sealant to fill hole.
    Hole will be approx 8~10mm dia.
    Has anyone done this ?
    Any tips advice
    Jim
  2. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,817
    7,814
    Plymouth
    Hi Jim not put awning lights but drilled a few holes for solar cables to enter van .Cleaned area (fiberglass) with acetone drilled required hole 10mm dia passed cables though suitable skin gland fitting.cut cables to suitable length on inside of van
    Then sealed drilled hole and skin fitting with sicaflex and let it set fixed cables to required terminals and secured . job done. Worked for me and cables out of site and no ingress of water etc.(y)
  3. JimboT
    JimboT Funster
    Nov 6, 2013
    245
    167
    Welwyn Garden City
    Jim
  4. makems
    makems Funster Life Member
    Sep 23, 2011
    2,720
    11,059
    Ingleby Barwick,,Teesside
    We have a long LED light strip under the awning casing. It is wired into the existing LED light over the hab door thereby avoiding the need to drill any holes.
    The cover popped off the light and it was a doodle to wire it in and the cover still fitted over the skinny backing for the LED strip.
    • Like it Like it x 1
  5. JimboT
    JimboT Funster
    Nov 6, 2013
    245
    167
    Welwyn Garden City
    Did think about doing something similar but would have bit of cable running from awning to light think it would not look good.
    Jim
  6. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,630
    3,461
    Telford, Shropshire
    Dril the hole slightly upwards from outside 'cos water doesn't run uphill.
    D.
    • Like it Like it x 3
  7. makems
    Sep 23, 2011
    2,720
    11,059
    Yes true. In our case the LED strip runs the full length of the awning so there is no cable visible, just LED strip
  8. JimboT
    JimboT Funster
    Nov 6, 2013
    245
    167
    Welwyn Garden City
    No real issues fitted two Fiamma lights maybe should have fitted three.
    The light end cap design is not great modified one end with dremel hand tool.
    Fitted lights to awning drilled two 5mm holes 60mm from each end.
    [​IMG]
    then drill fitting holes in awning body
    [​IMG]
    bought some rubber grommets from halford to protect wiring
    [​IMG]
    drill hole for wring wring running inside waning body to front light then into van.
    grommets fitted
    [​IMG]
    fit wiring
    [​IMG]
    fit front bracket and drill for wiring i wanted front light cap to cover hole into van to insure weather seal.
    [​IMG]
    Drill hole into van I wanted this to come into front cupboard that has out side light and 12v supply close to hand.
    [​IMG]
    sealant used
    [​IMG]
    lights fitted and test with 12v battery
    [​IMG]
    going to spur off one of points in picture below have order fiamma switch with dinner will post final pictures when that arrives
    [​IMG]
    This took me about 1.5 hours to do 1st time if doing again 40mins!
    Regards
    Jim
    • Like it Like it x 2
