Drilling a motorhome acrylic window. (1 Viewer)
Mar 26, 2009
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
Has anyone drilled an acrylic window?
I have condensation between the two surfaces and before buying a new window would like to drill a couple of holes in an attempt to remove the moisture and reseal by inserting some plastic bungs. If you have drilled a window did you drill a small pilot hole first followed by the correct size or did you go for the correct size hole in one pass? How critical is drill speed? Any other tips/pitfalls to be aware of?
Thanks (in advance) for any help you can offer.
Emmit
8,032
17,749
Cornwall
Pilote Explorateur
Jan.2014
Acrylic is 'Soft'.
It will easily melt if subjected to heat. That includes using drill bits on it. (try touching a drill bit after it's been used.)
First of all, stick a piece of insulating tape at the point of drilling. That will stop the bit from wandering. I would drill a pilot hole with a very small diameter bit and then "Slowly"!!! drill the right hole, not using a lot of pressure and take the bit away regularly to cool down.
Good luck
Jan 24, 2010
2,440
4,848
Adria Twin
make sure its a very sharp drill as well !!
One thing though...you need to try an find whats causing it first...probably a delamination on the edges, or around window locking/opening bits and bobs. Could run some Capt Trolleys on any of the edges, should solve it
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Our windows had a recall, four screws to each window because some flew off.
These windows have two little pressure vent at the top corners, why reseal ?
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Do the windows not have breather holes? Ours have a hole on each side through the inner skin, near the struts. The holes are filled with plastic plugs that have a cross-shaped air vent (hard to see).
signworks
330
379
wrose bradford
swift bolero
since 2009
sorry to disagree with bungy but dont use a sharp drill blunt the drill bit on a piece of steel as a sharp drill will grab and possibly crack the window if you can try a test piece of acrylic
before you drill use sellotape were you are going to drill the oil in the tape will cool the acrylic down and stop it from melting and give you a clean cut
try do it in one pass no pilot hole unless you are drilling larger holes than 12mm
cheers tomi
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Drilled one or two in the past and the same as number plates :
slightly blunt drill and not a lot of pressure let the drill do the work ,drill though a bit of masking tape or similar to stop slipping .
As has already been asked have you not got small robber breather bungs ?
Jan 24, 2010
2,440
4,848
Adria Twin
different windows type
Phil is looking to reseal after getting rid of the moisture,it will just happen again, but yeah, could leave the holes open
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
well...looks like ive been lucky sofar then with the sharp drills and plastic/perspex(y)
Very. There is special sharpening angle for plastics, very shallow.
I'd even suggest a hand drill if he has such a thing.
musson
487
165
grantham
low profile
since Jan 2014
you could try a soldering iron with pointed bit,having said that all the caravans i have owned had plastic plugs
TERRY&PAULINE
116
107
coventry
autocruise starfire
since 1987
we had this problem with our door glass drilled 2 small holes from inside at the bottom cured the problem didn't seal them up seems ok now
Taran_Las
Mar 26, 2009
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
Thanks for all the suggestions.(y) Much appreciated (even from him who can't spell;).)
Strangely enough only one sliding window & Heiki have plastic bungs in them. All the other windows are 'sans bung'. I'll have a look on eBay for some acrylic to perform a test on.
MattR
4,104
38,854
Beds
Panel van
Years
Our windows get water in then it dissapears without any help from us. Is the water in your windows all the time? If you do need to drill, can you drill into the area that has water to help keep the acrylic cool?
Taran_Las
Mar 26, 2009
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
The water appeared last summer after the van had been in for repair. The workshop (in France) was incredibly hot early in the morning (not sure if this contributed to the problem). This is only affecting one window. Noted - a good suggestion to drill into the area holding the water (for cooling). The sliding window has one bung at the top and one diagonally opposite at the bottom.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I had no problem using a regular HSS bit drilling acrylic. The problem I envisage for you Phil is swarf and where it will go as you break through. It may be tiny but once you notice any you'll never get it out of your mind, draw the blind! :LOL:
DBK
18,022
48,091
Plympton, Devon
PVC, Murvi Morocco
I would suggest the holes should be at the top.. that's where they normally are
when the internal air warms up it rises carrying the moisture ..
As above, but for a slightly different reason. Counterintuitively, dry air is denser than moist air, so the holes should be at the top. The reason is water molecules are lighter than nitrogen molecules.
JeanLuc
3,304
2,199
Warwickshire
At the risk of being 'a dog worrying a bone' I am surprised there are any windows sans bung - is it possible that a breather vent is concealed in some other fixing on these windows? e.g. in the strut or closure mountings.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
One of ours seems to have a few drops inside it as well. :(
TERRY&PAULINE
116
107
coventry
autocruise starfire
since 1987
The reason I drilled the holes at the bottom was to let the water run out that had formed, not had a problem since
Taran_Las
Mar 26, 2009
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
Good point. I'll examine the offending window with the metaphorical microscope. Thanks for the suggestion Philip.
Taran_Las
Mar 26, 2009
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
Strange you should mention that Andy. The sliding window has a bung missing. A kamikazi fly found its way in, but alas, not out. That (pardon the pun) has bugged me enormously.:LOL:
Dec 12, 2010
5,409
21,558
Cumbria
since 2011
Last September, when they were combining the field behind our house, 5 of those tiny harvest mites got into my pc screen. They show up as tiny out of focus hyphens, does my head in !
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Suggestion? when finished and dry, Insert several grains of Silca Gel. Before resealing?
The guys who make Double glazing do that, before they inject the nitrogen to void the oxygen/Air. Watched them do it in the factory, whilst waiting to "tip" once.
Pete
Taran_Las
Mar 26, 2009
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
I've ordered a piece of acrylic from eBay. I've also located my hand-drill. I can get some practice in ready for the day I summon enough courage to have a go at the window. Thanks for all suggestions, tips and pitfalls. They've all been duly noted(y)
:cartoon:
