Draughty roof skylights
Discussion in 'Motorhome Chat' started by knokinonabit, Dec 10, 2013.
  1. knokinonabit
    knokinonabit Funster
    Dec 28, 2011
    2,483
    2,453
    Stokesley, North Yorks
    Can anyone help me find a thread that was on here a while ago about how to stop the draught howling in through the roof skylights ?
    I've searched for ages and can't find it and feel such a numpty. :Blush:
    Must be an age thing.
    I seem to recall it was done by putting some kind of strip onto the glass/plastic edge to form a seal.
    It's amazing the amount of cold air that comes in from there. All the trouble that manufacturers go to with insulation and heaters etc. and then leave bl**dy holes in the roof.
    Looking forward to all of your replies, no matter how much you rip the p**s out of me. :BigGrin:
    • Like Like x 1
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,947
    17,614
    YO11 2BD
    are you sure the draughts arent coming through the vents around the skylights.
    many types have these vents for ventilation :)Doh:) when the light is closed.
  3. SteveandDenise
    SteveandDenise Funster
    Sep 26, 2011
    530
    681
    Spalding LINCS
    Roof lights
    Is this the heki roof lights if so the place to get the seals is www.leisurespares.co.uk I think the cost is £6.75 ea.
    • Like Like x 1
  4. knokinonabit
    Dec 28, 2011
    2,483
    2,453
    I thought that could be the cause, but if I put my hand up between the roof and the glass/plastic I can definitely feel a draught.
    • Like Like x 1
  5. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,620
    2,191
    Rutland
    If it's the vents around the window,I cover mine with masking tape if it's really cold.
    Vlad
  6. knokinonabit
    Dec 28, 2011
    2,483
    2,453
    Sometimes when we are driving along all nice and cosy there is a sudden icy blast down the back of our necks and down to our legs.
    If this is coming through the vents is it possible/advisable to remove the vent covers and block off the vents by some means, such as gaffer tape ?
  7. knokinonabit
    Dec 28, 2011
    2,483
    2,453
    Cheers Vlad. I might give that a try. :thumb:
  8. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,154
    13,979
    Heavan
    hi, we used to have this problem. I got some foam lagging from been and qued and placed it where the rood shuts. I then wound down the roof lights and then bingo gob done. It's basicall where they do not completely seal between the roof and the hatch.
    i done this way because as soon as the warmer weather comes, nothing is permananet.
  9. knokinonabit
    Dec 28, 2011
    2,483
    2,453
    That sounds like a damn fine idea to me. :thumb:
    Good luck on Sunday.
    I only live a couple of miles from Roseberry Topping but I will be over at Scarborough that weekend driving a fairground organ to charity do's in Whitby, Rosedale and Scarborough town centre.
  10. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,545
    9,981
  11. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,961
    11,396
    E Yorks
    I got some draught excluder (the foam type you stick on domestic house external door frames) which I found fitted perfectly into the channel running round the edge of the roof light 'glass' and mated up to the frame below when closed, thus preventing any draught from getting in, I had to use 2 layers of the stuff to get sufficient depth on it but it certainly worked a treat.
    http://www.ebay.co.uk/itm/Window-Do...ecorative_Accents_LE&var=&hash=item20d9b1bbb8
  12. knokinonabit
    Dec 28, 2011
    2,483
    2,453
  13. knokinonabit
    Dec 28, 2011
    2,483
    2,453
    I've got a roll of that in the garage. :thumb:
  14. Minxy Girl
    Aug 22, 2007
    9,961
    11,396
    E Yorks
    Just one word of warning - it sticks like sh*t to a shovel so make sure you have it in the right place first time ... I did it by gradually peeling off the backing and pushing it in at the same time (if you have fat fingers find something of a suitable size to push it in with) - if you try to take all the backing off first you will come unstuck ... or rather get stuck up ... errrr stick it up where you don't want it ... oh heck, I think you get my drift! :RollEyes:
    • Like Like x 1
  15. knokinonabit
    Dec 28, 2011
    2,483
    2,453
    You mean I could end up with a sticky end. :Wink:
  16. greygit
    greygit Read Only Funster
    Aug 11, 2009
    274
    232
    Forest of Dean, Glos, France and Spain
    We had this problem with one of our skylights so I got Highbridge to fit a deflector just in front of it, had to pay although we bought the van from them new six month prior to them doing the work. :Sad:
  17. rolandrat
    rolandrat
    Jan 5, 2013
    436
    257
    Lancashire
    Numerous owners have complained about Autotrail roof lights being over draughty, you need to fill them up with sealant to cure it. They did mine at the factory, it stopped it.
  18. knokinonabit
    Dec 28, 2011
    2,483
    2,453
    Ours has a deflector but it all depends on which way the wind is blowing and how strong it is. :BigGrin:
  19. knokinonabit
    Dec 28, 2011
    2,483
    2,453
    I feel a fool and annoyed all at the same time.
    Because the cold coming in was so bad I asked the dealer to check out the seals when it was in having warranty work done. (see Autotrail woes)
    The dealer said that the seals were fine and it was coming through the vents. I took them at their word.
    Having had enough of the draughts and cold, today I climbed up and had a look for myself. Only one quarter of each rooflight has a seal, on the hinge side. The rest has nothing, so the elements just blow in, which would account for finding leaves and dirt in the MH after it has been swept out.
    Now you see why I feel a fool and am annoyed together.
    The dealer will be finding out tomorrow morning, first thing.
    I was only there this morning, as I passed on my way to an appointment elsewhere, to enquire about the work that is still waiting for parts.
    I just don't trust them to do anything at all now, even if it is warranty work.
    I will also be ringing Autotrail to see what their excuse is and what they are going to do about it.
  20. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,351
    5,368
    East Sussex 01-580-881288
    You can get these:
    Fiamma Universal Spoiler
    New Fiamma Universal Spoiler, universal aerodynamic roof spoiler; ideal for reducing vibrations and rooflight noise while travelling.
    Made with UV-ray resistant sturdy PVC material. It can be shortened to adapt itself to the different rooflights with dimensions from 110 cm to 28 cm. Easy to install without tools and without drilling the roof: can be attached with suitable adhesives (Sikaflex). Complete of smart lateral aerodynamic end caps.
    Dimensions: 110 x 20 x 12h cms
    • Like Like x 2
