Draining vehicle battery
Discussion in 'Tech/Mech General' started by spsmith45, Nov 24, 2012.
  1. spsmith45
    spsmith45 Read Only Funster
    Jun 7, 2012
    4
    Harrogate
    We have a 2011 Swift Bolero 600EK Compact. Since we have owned the motorhome we have had an issue with a draining cab battery. The battery has been tested by the RAC and is fine. Brownhills also tested it and measured a minimal drain.
    And yet.. after about a week, maybe two, there is not enough charge to start the van.
    Nothing is left on apart from the Toad Alarm which Brownhills said is draining a very tiny amount 0.05 amps, I believe. (It has a red light on the dashboard.) basically Brownhills said there was no problem.
    So, I have jump started the van from my car. OK, but a bit of a faff. I have bought a connector to allow me to hook up the van from my home socket.
    When plugged in I was able to start the van this morning, but I got a high pitched whine from the control panel, so I switched off.
    So, my questions are: will my vehicle battery charge as well as the leisure battery when I am hooked up. Secondly, is it OK to start the engine when just having hooked up on a low cab battery? Lastly, if there is almost no measurable drain on the battery, why does it seem to be draining?
    Thanks in advance for any wisdom.
    Worth getting an optimiser?
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,770
    6,291
    South yorks
    Hi the alarms are notorious for flat battery in 2 to 3 weeks.
    Once on hook up you may be able to choose wether engine or habitation battery is charged or buy a gizmo like battery master to divert charge to engine battery once the leisure battery is full
    Terry
  3. hilldweller
    Dec 5, 2008
    27,551
    26,638
    Macclesfield
    I've seen that written many times. 3 weeks and you are dead sort of thing. All down to the FIAT electronics it seems.
    Do a search here for Battery Master. That, and other similar products, top up
    your starter battery from your leisure battery.
  4. ramsthom
    ramsthom Funster
    Nov 23, 2011
    154
    96
    durham
    Most Swift motorhomes when on EHU charge the cab and leisure battery. Check the settings in the power control unit. Its nomally set on Smart charging which switches between cab and leisure batteries automatically. Alternatively the control panel normally above the habitation door can be used to manually to select which battery to charge by selecting cab or leisure.
    Hope this helps.:Smile:
  5. injebreck99
    injebreck99 Funster
    Dec 5, 2011
    1,207
    1,315
    norfolk
    I have exactly the same model M/H, I keep it on hookup all the time when at home, both batteries are always fully charged, and I have never had a drained battery,( no alarm fitted), ever, even after weeks of not using it. I would see if you can disconnect the alarm and see if the condition reoccurs.
  6. spsmith45
    Jun 7, 2012
    4
    Harrogate
    Thank you for the replies so far. Looks like I need to keep it hooked up as far as possible. It's still odd that the battery drains despite measurements suggesting the contrary!
    I'm not sure how useful the Toad alarm is and may get that disconnected at some point.
  7. icantremember
    icantremember Funster
    Sep 2, 2010
    5,396
    7,498
    Nr Watton in Norfolk
    The whine is not a problem, it is an alarm to let you know you are still hooked-up to the mains.
  8. ubuntu1
    ubuntu1 Read Only Funster
    Feb 13, 2008
    155
    44
    Derbyshire
    cab battery
    Its a very common problem. There are ways around it and if you are handy you can do the work yourself, if not get an engineer to fit a battery to battery charger.
  9. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,611
    3,428
    Telford, Shropshire
    It also depends on what test is being carried out on the battery. I have two Sealey brand battery testers, one cost 45 quid the other cost closer to three hundred! The 45 quid job will identify a totally buggered battery every time but frequently identifies sick batteries as ok if they've just been charged (possibly just been given a long run) whereas the more expensive one correctly identifies them as fubar. I've just replaced the starter battery on our camper because it would struggle to start after a week of standing (camper is based on 96 Iveco Daily so minimal electronics and no alarm fitted). Local pub landlords car has been playing up recently, tested this morning and it gave 35% current capacity, this is a 9 month old Banner Starting Bull.
    One of the biggest killers of lead acid batteries is being left in a discharged state for long periods, this frequently occurs at dealerships where stock vans can lay around for up to 12 months or longer.
    D.
    • Like it Like it x 1
