Drainage on motorhome
Discussion in 'Motorhome Chat' started by Titch, Apr 26, 2013.
  1. Titch
    Titch Read Only Funster
    Apr 26, 2013
    Fordingbridge, Hants
    I am new to motorhoming although i have had a caravan in the past so not a complete novice!! :/
    My motorhome (Fiat Ducato Riveria Ci) has a waste tank at the back where you pull the lever and the water drains out over a drain which is all well and good at campsites which have this facility but when i go on to a serviced pitch how do i drain the water as i can't work out how to fix a drain hose to the tank opening as it has a 66mm diameter and the pipes don't come that big and i can't seem to find a reducer??
    Any suggestions welcome please??
    Thanks Titch
  2. scotjimland
    Jul 25, 2007
    28,940
    25,628
  3. chaser
    chaser Funster
    Feb 16, 2013
    7,714
    8,789
    uttoxeter
    Just leave it open like everyone else. :hardhat:
    • Like it Like it x 2
  4. chaser
    chaser Funster
    Feb 16, 2013
    7,714
    8,789
    uttoxeter
    Seriously , both my son and daughter have these vans and I am afraid that's what they both do and I honestly can't see what else you are supposed to do, it's a great big hole miles under the van , are you supposed to crawl underneath with something or what, ok if you can draw over something , in France that's ok, but what you do here I have no idea. :Doh:
  5. Terry
    Terry Funster
    Dec 27, 2007
    10,771
    6,291
    South yorks
    Try moving the van to the part where none seviced pitches empty-then move back to your serviced pitch :Smile:
    terry
    • Like it Like it x 1
  6. Nirvanauk
    Nirvanauk Funster
    May 8, 2011
    1,425
    7,806
    God's county. North Yorkshire.
    How about a short piece of bike innertube and two jubilee clips to reduce it?
  7. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,639
    1,471
    West Midlands
    I have to agree. We have the same problem and find that so many sites that claim to be motorhome friendly don't have a drive-over drain (and seem puzzled when asked) Others may have one but need acrobatic skills to drive over. A simple gutter emptying into the drain would make the whole process available to a wide range of vehicles. As said, this seems to be the norm abroad where motorhomes seem better catered for rather than being pushed into adapting to caravan facilities.
    Wyn
  8. motorhomer
    motorhomer Read Only Funster
    May 17, 2008
    578
    317
    South Shropshire
    Quite right! Motorhomes have drains in the middle, on the left, on the right, front and rear! Very few can really connect to the drains on fully serviced pitches, but I would argue it doesn't matter too much. I think CI's tanks are quite big so would last a few days - just drive to a drain where you can empty every few days. We empty when we leave, or after about 4 days on the rare occasions we stay longer, sometimes using a bucket. Too many UK sites (especially Caravan Club) have manhole covers that you dare not remove before driving into place because of the risk of dropping into, but after you are in place the manhole cover is under the van!
  9. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,111
    13,514
    Ramsey, Isle of Man.
    Agree, some sites are poorly set out.
    Mine, like all American RVs have the waste system situated on the left side of the vehicle, towards the rear. Simple to use, connect a length of 3" sewer hose to outlet, and place the open end into a waste point or sewer, open black tank emptying valve, when empty, close valve. Then open grey waste valve, this will clean the sewer pipe and in effect flush the system and sewer. Some US black tanks have a flushing system too. Simple.
    Also they have city water connections, where through a pressure valve, the hose from the fresh water tap is connected directly to the RV, and bingo, you have running water on board, without the need for the water pump to be running. It's not rocket science.
    All US campground pitches have their services on the correct side for RVs, pull up on pitch, connect electricity, connect water, connect waste pipe.
    They do have proper fittings for the sewer pipe on the ground, a small screw in cap is removed, and the open end of the sewer pipe has a connector that fits into this. So a tight fit, no smells, and all you have to do when the tank is full, open valve, and empty, open valve and flush. Very civilised.
    Makes some 'fully serviced' pitches in the UK seem backward.
    Craig
  10. frankhanna
    frankhanna
    Apr 2, 2013
    64
    83
    Isle of Man
    Drinage...
    Hi Titch,
    I have the answer... (picture uploaded) I have suffered from this for years and then I inadvertently came up with the answer this year. Buy a very large plastic basin with handles, they only cost a few pounds and keep it in your garage. There you can put things in it so it doesn't take up a lot of space. When I need to empty the tank I just drain water into this and carry it to the nearest drain. Three carries empties the entire tank.
    I never use anything else now. Simple cheap and it works.
    Frank
    Http://www.frankhanna.com/blog/
  11. meanders
    meanders Funster - Life Member Life Member
    Jun 28, 2008
    571
    344
    Ipswich, Suffolk
    When we first had our motorhome we had the same problem but we managed to get some pond hose the right size and added a screw connector that just screws into the outlet which works fine on service pitches
  12. Gromett
    Gromett Funster
    Feb 27, 2011
    8,189
    15,031
    UK
    If you are not a diy person, then a friendly plumber would be able to bodge something together for you. On one of mine I ended up getting a couple of different sized pipes that slid inside each other. I glued them all together along with a (I think) 2" elbow and ran the pipe to side of the van. I then had another elbow and a short piece of pipe.
    I could then put a waste hog underneath this and opened the valve.
    Worked a treat.
    The only scary bit was screwing the clips to the underside of the van as I was worried about damaging it. But a bit of underseal before and after sorted that concern out.
  13. chaser
    chaser Funster
    Feb 16, 2013
    7,714
    8,789
    uttoxeter
    That's ok if the manhole is in the middle of the road, but most aren't. Ok so you can put new pipes on and mess about but what were they designed to do.
  14. mentaliss
    mentaliss
    Nov 2, 2012
    657
    308
    Lancing
    try visiting a yacht chandler they should sell 50mm + size flat hose, may also stock a screw
    adaptor to fit your female end
  15. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,807
    1,027
    Cark, Cumbria
  16. happypre65
    happypre65 Funster
    Nov 12, 2010
    139
    49
    hi,I bought a piece of water hose with a rubber funnel end on it,and for sites with no serviced pitches a folding water carrier,takes up hardly any room and is very light,regards H:BigGrin:
  17. ukbill
    ukbill Funster
    Nov 3, 2011
    4,970
    4,904
    benidorm
    if its the same as mine the tank has a overflo on it so dont worry to much just place a bucket beneath the tank to take the overflo water empty this when needed and empty the tank when you leave the picture with the 50mm pipe (i think its 50mm) is a good idea but beware the ci tanks can be low to the ground so for a permanent fixture it could cause problemes when on the road mine has 2 tanks the front is for the sink only and the rear is for the shower and basin in the bathhroom this tank will have a 22mm waste pipe on it i rarely use the front tank now if i need to washup dishes this is done in a bucket and disposed of on the pitch next to me or on jaws pitch if he is on site :Smile::Smile::Smile:
  18. chaser
    chaser Funster
    Feb 16, 2013
    7,714
    8,789
    uttoxeter
    Theirs are 181s and I can't see how you could get buckets out from under there without scrabbling about and getting covered and how do you know how full y bucket is when you are at the back pulling a handle, you couldn't hook up to a service pitch either, and the size of the hole , I would say would fill a bucket before you had chance to look at it
  19. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,111
    13,514
    Seems to me a lot are poorly designed.
    Craig
  20. chaser
    chaser Funster
    Feb 16, 2013
    7,714
    8,789
    uttoxeter
    Uk not designed for motorhomes , more to the point :Angry:
