Downrating Motorhome Weight (1 Viewer)
lorger
9,651
90,472
Dumfries
Knaus Sun 650MEG
I have just sold the MH and the new owners are needing it downrated to 3500 from 3850, when i uprated it there was no physical changes just paper work.
I called DVLA yesterday and was told i would need to get a certificate of plating, basically they said take it to a weight bridge and get a cert of the weight to prove its still under 3500.
They have told me i then just fill in the log book part for the tax class and put new weight in so just wondering if anyone has done this and is this the correct way.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
yes that should be ok. down plating is easy.
there will be more tax to pay.
a simple letter explaining why and that no changes were needed could just help.
but it will be simple .
at one time you just went to local office but these days thats gone .
lorger
lorger
9,651
90,472
Dumfries
Knaus Sun 650MEG
Thanks Alan i thought it would be just reassuring to here from someone who knows
Feb 22, 2008
12,260
45,022
Norfolk
Nearly Tugging
Since 2004
I have just had my Hymer downplated by SVTech at a cost of £144.
I provided the weighbridge tickets and they produce the new plate, verification letter and V7 for sending to DVLA , all done in a few days. If you tax it at phg , don't forget to send DVLA the difference as plg is a bit more
lorger
lorger
9,651
90,472
Dumfries
Knaus Sun 650MEG
Larry did you just use a private weigh bridge or did you use a DVLA/DSA one
Feb 22, 2008
12,260
45,022
Norfolk
Nearly Tugging
Since 2004
It was a private one on a farm, they will all be calibrated for accuracy and should provide a printed ticket with both axles and complete weight.
My was weighed with a 1/4 fuel all tanks dry and no driver and was 2780 kgs so sufficient payload
CWH
5,137
247,344
UK
WildAx PVC
From November 2013
Dealers told me they could do it & it would cost close to £1000????? Enough for us to decide to put up with the higher weight. Can anybody explain please how they could come up with this amount?
Also, I think I must have misunderstood - I'm under the impression that the weight we're talking about is when the van's loaded, so how can a weighbridge weight "to prove its still under 3500" be of any use? What am I missing here please?
Feb 22, 2008
12,260
45,022
Norfolk
Nearly Tugging
Since 2004
The object is to prove there is adequate payload to be able to keep within the new gvw so a miro is required. Some new vans include full fuel and 75kg for driver , others do not.
£1000.........on the make I think
Reactions: CWH
CWH
5,137
247,344
UK
WildAx PVC
From November 2013
Ah ... thank you. So a bit of subjectivity involved then, in terms of what you'd carry. (I realise it's then up to the driver to make sure the loaded van is under 3500.)
Seems unlike this dealer to beef up the cost to this extent!
Feb 22, 2008
12,260
45,022
Norfolk
Nearly Tugging
Since 2004
Perhaps misunderstood and was quoting for an uprate of weight which could potentially entail tyre/brake /suspension changed.
As i posted earlier SVTech charge £144
Reactions: CWH
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
I thought for a downgrade all you needed was a weighbridge ticket and write to the DVLA
lorger
lorger
9,651
90,472
Dumfries
Knaus Sun 650MEG
Yes that's what I was told just a ticket and fill in the correct section in the log book.
Feb 22, 2008
12,260
45,022
Norfolk
Nearly Tugging
Since 2004
Yes, that corrects the V5 registration document, but you still require a plate displaying the new gvw and axle weights and dvla dont produce those.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
the op already knows the axle weights and possibly still has the old plates . even so its a scrible on a sticker if they want to.
remember in the first post they say they uprated the vehicle .
lorger
lorger
9,651
90,472
Dumfries
Knaus Sun 650MEG
Yes old plate still on van next to the new sticker which I will just score out
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
when i down plate vehicles i leave the higher plate there in case of future needs .
i use a voluntary down plate sticker . next to the original ones .
Feb 22, 2008
12,260
45,022
Norfolk
Nearly Tugging
Since 2004
Yes in my case I have left the higher plate
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
the daftest thing is you can down plate yet the original train weight stays .
mind it suits what i do.
i,m sure larry would be better off with a fifth wheeler . ha ha .
i know we have been here before .
its the answer for over 70 yr olds for sure.
Feb 22, 2008
12,260
45,022
Norfolk
Nearly Tugging
Since 2004
We like fifth wheelers but we are tourers and dont stay put for long, so a modest motor home will suit our needs best.
The other thing Alan is with the new plate , front and back axle weights also stay the same which if checked by dvsa gives a bit more flexibility.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
i know its so daft you couldnt imagine what goes on in their minds . if i down plate mine i can leave the axle weights and the rear would be a ton over the gross vehicle weight .
its hilarious really .
the 7500kg down plated can still have 5200kg as its rear axle weight.
the fronts stay at 3100kg .
you can see how confusion beats them .
specially as it keeps the 11ton train and can be driven on some b+e driving licences .
its just a game really.
Feb 22, 2008
12,260
45,022
Norfolk
Nearly Tugging
Since 2004
Yes, barmy :rolleyes:
kcy
783
899
east yorkshire
chausson flash
since 2012
When ours is out of warranty we'll be putting it up to 3850 from 3500. Can't understand why anyone would want to lower it.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
i lower trucks so they can be driven on a blicence .then as many before 2013 have b+e they can use the full trainweight of the original listing .
like i say at 70 i will lower mine and slide the trailer wheels /axles forward to lighten the weight on the fifth wheel. and i dont have to worry about licencing .
mind i will then have to mot the truck . always a negative somewhere.
Jul 30, 2022
3
Burstner
Hi I’m thinking of buying a mh which weighs 4000kg is it possible to down plate it ?
Regards Adam
Lenny HB
53,216
149,256
On the coast in West Sussex
Hymer B678 DL
Regards Adam
Very unlikely but to check, load it with everything you take with you for a trip including people water, fuel, food & beer then get to a weighbridge if you are under 3500kg you should be OK. Then you need to unload everything including fuel & weigh it again to prove to DVLA if can be run at 3500kg with enough payload to be useable.
You will also need a weight new plate, officially can only be obtained from a registered engineer but you can get "show plates" on ebay.
Jul 26, 2010
306
346
Cumbria
Van conversion
To many to mention
I think it all depends on who you get at DVLA. We tried to downplate a converted ex minibus so family could use it. Weight at weighbridge empty 2.5 tons. Wanted it down graded from 3.8 to 3.5. Numpty at DVLA insisted I needed a weighbridge ticket saying 3.5, I tried to explain if it weighed 3.5 empty I would not have any payload. His response was Madam I own a caravan and fully understand payload, I need a weighbridge ticket stating 3.5 before I can downgrade it. Needless to say we stayed with original weight & sold the vehicle.
