Double the electrics.
Discussion in 'Tech/Mech General' started by Bryan, Sep 20, 2010.
  1. Bryan
    Bryan Read Only Funster
    Jul 19, 2007
    2,096
    342
    Hi,
    If I have 7 amp hookup can I connect my camper to two ehu connections instead of one and get 14 amps?
    If so, is it as easy as using a splitter (see pic) in reverse?
    Bryan
  2. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    interesting argument
    OK, we must have an expert that can solve this one..makes for an iteresting argument.. who gets what at what amps?:Blush:
    Bob:thumb:
  3. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    I know the yanks do this, you can buy the widgets to achieve:Eeek:
    I know if we turned all we have on we could exceed 7 amp, but why would we/you?
    Just curious?
  4. slobadoberbob
    Jun 1, 2009
    6,159
    1,970
    like sticking your finger in
    Simon, Just like sticking your finger into the elctric fly swat to see if it works?:Blush:
    Bob:Eeek:
  5. scotjimland
    Jul 25, 2007
    28,934
    25,603
    Site EHU supplies are run in three phases + neutral .. one phase per socket .
    it would work if both on the same phase but as you don't know this .. it's a big NO .. do not do this
  6. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Thought about it, but not daft enough to try, now lets see how many admit to it:Rofl1:
  7. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,739
    5,967
    Mansfield,Notts
    During a recent electrical safety inspection and certification carried out by my oldest boy Simon. at Newark one of these systems was found on a RV It was pointed out that
    Although unlikely, it is possible to pick up two different phases
    and input 480Volts:Eeek: using this method
    Go for it brian your electrical problems will be over:Doh:
    Geo
    Make my day
    Ask yourself Punk!!!
    Do you feel lucky
  8. Terry
    Terry Funster
    Dec 27, 2007
    10,759
    6,253
    South yorks
    Hi Bryan, I could well be talking b-----ks here but most UK camp-sites are 10 OR 16 amps so why is your van limited to 7 ? Does it trip above 7 ? If that is the case then fit a bigger trip.
    terry
  9. Geo
    Jul 29, 2007
    9,739
    5,967
    Mansfield,Notts
    No Bryan is just greedy he knows there is 48 amps out there on a 16 amp site and he's proberly already working on a "relay" powerd self circulating power input that will suck 16 amps off each phase in turn:Doh:
    Geo
  10. Terry
    Terry Funster
    Dec 27, 2007
    10,759
    6,253
    South yorks
    :Rofl1: or his new lappy takes more power than he thought
    terry
  11. scotjimland
    Jul 25, 2007
    28,934
    25,603
    or planning an extra special Christmas display, the glowing RV ..... :Eeek:
  12. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,942
    I'm sure Haganap will tell us how enjoyable it is at Lincoln :Rofl1::Rofl1:
  13. Bryan
    Jul 19, 2007
    2,096
    342
    Hi Terry,
    Van is not limited to 7 amp, just asking the question; same question could have been worded 2 x 16 amps to get 32 amps but I wanted to take the cable used out of the equation. :Smile:
    Bryan
  14. Bryan
    Jul 19, 2007
    2,096
    342
    Thanks for all the quick replies.
    The consensus seems to be a resounding NO! :Rofl1: due to phases or something...That I know nothing about :Doh:
    So given that MY way is not so clever, is there a way to do it at all?
    Bryan
  15. hilldweller
    Dec 5, 2008
    27,284
    26,276
    Macclesfield
    Not if Jim's right and there is a risk of more than one phase.
    If you tested for single phase ( 0V from live to live ) then you could in theory split your wiring into two semi-equal loads and have two hook-ups, you'd use a splitter if you found a single 16A supply.
    Hmmm. Talking theoretical, there is a way with 2 phases. Two BIG chargers, one off each phase and you run everything of a whopping inverter. This would work with single or two phases. Might be able to squeeze a relay in there somewhere. There might be a voltage issue because all of a sudden you are in command of a 390/415V system. Different regs ?
    See if you can find one 12V 150A and one 12V 300A charger before you get too excited. And a 3 or 4kW inverter and some very thick wire.
    Can NASA copy with 300A ?
  16. Terry
    Terry Funster
    Dec 27, 2007
    10,759
    6,253
    South yorks
    Lost me Bryan :Rofl1: I suppose you could wire the left side of the van to work off one hook up and the right off tother :Rofl1::Rofl1:
    terry
  17. tofo
    tofo Funster
    Oct 1, 2007
    6,647
    6,428
    Kirby cross further from londin
    and convice the neighbouring pitch its their lead
  18. Simannjo
    Simannjo Read Only Funster
    Apr 18, 2009
    31
    Nottingham.
    Connecting 2 leads to different outlets would double the amount of current avaliable...
    BUT...
    As has been mentioned, the possibility of one socket/lead being on one phase and the other socket/lead on another phase is possible and not advisable... Here's why...
    As a rough (but reasonable) guess you would have 415V between the lives of each cable... The common connection being the RV or connector/adapter and in effect a dead short on a 3 phase circuit.
    The PFC (Prospective Fault Current) on a 3 phase installation is very likey to be a MINIMUM of 2500 amps and probably higher... All through a 2.5mm Hook-up cable designed to carry a max 27amps...
    Be nice to watch though! :Eeek::Eeek::Eeek:
  19. Ash
    Ash Trader - Service & Repairs Life Member
    Sep 22, 2007
    768
    190
    The Midlands ( Nuneaton )
    Be careful mate , we were in Spain with friends 2 yrs ago and he did that , there was an all mighty bang and he had blew the electrics up on site :Doh::Doh:
  20. scotjimland
    Jul 25, 2007
    28,934
    25,603
    One or both of the outlet's MCBs would trip first...
