double skillet HELP please!
Discussion in 'Cooking in your Motorhome' started by enery8, May 30, 2013.
  1. enery8
    enery8 Funster
    Oct 11, 2012
    532
    578
    Our double skillet arrived today and Sue is attempting to roast a whole chicken and getting frustrated a bit. Any advice would be really apreciated.:Wink:
  2. lindylou
    lindylou Funster
    Sep 5, 2008
    443
    218
    York
    Heat both sides of pan first
    Did you get the diffuser. If so use it and cooks on very low heat. If no diffuser just keep heat as low as possible. No extra oil or liquid.
    Keep lid on to keep heat in and make sure pan with lip is on bottom.
    Lin
  3. Carol
    Carol Funster Life Member
    Oct 2, 2007
    10,587
    15,354
    North Wales.
    Like Lin says heat both sides of the pan though don't get it to hot, once it is quite warm put the chicken in and bring it up to the heat as the fat won't be running out yet, turn the pan over a few times until the fat starts to run, then just let it cook away.
    Don't forget keep it on a very low heat once it is hot, it should keep its heat, should take about a hour to cook depending on the size of the chicken, the skillet does cook them beautifully.
    If you have not got a diffuser, I would get one, you can pick them up at any hardware store for a couple of pounds.
    Hope you enjoy it.:Smile:
  4. enery8
    enery8 Funster
    Oct 11, 2012
    532
    578
    I have got a diffuser, haven't used it, (no idea how at present). Chicken was cooking 45 mins and not bad but pale, not browned properly on top but now know how to deal with that next time. Will brown breasts first then lay flat and leave it to cook untouched. Have covered again and left it for more time, so far about half hour. Will check it soon/ Juices are clear but its not as tender as when I cook them in the oven. I have got one cooking in the oven as will so will see which is best later.
    Does the diffuser lay over the gas flame and under the pots?
    Thanks for help Sue
  5. enery8
    enery8 Funster
    Oct 11, 2012
    532
    578
    Thank you Carol, I had heated both pots when I oiled and warmed them as a first time user but let them cool again while preparing the chicken when I only reheated one. Next time.....
    We did buy the diffuser as we had read what others said.
    I have just taken the chicken out and it looks as if it will fall apart, so looks well cooked.
    Sir told me not to turn the pans because the instructions said not meat because of the juices so I listened to him, :-( Will write down your tips to remind me next time.
    Thank you very much for your help,
  6. Carol
    Oct 2, 2007
    10,587
    15,354
    North Wales.
    Sue, the diffuser just put it over the gas ring then pans on top, it does help a lot with pies and things, but as you get the feel for the skillet you will be able to judge for yourself.
    If you are cooking a piece of Lamb or Beef I put the potatoes in with it, but not with chicken. I have had mine 9 years and just had a new one in case I can't get one when this one wears out.
  7. enery8
    enery8 Funster
    Oct 11, 2012
    532
    578
    Sounds good, I am never cook potatoes in the same pot as chicken as its jelly like juices rather than good tasty juices.
    9 years now thats a good reference.
    With yours and Lins help and seeing the end result I am already feeling more comfortable with it. Now hope it tastes as good as the one done in the oven which had rosemary sprigs laid on top while cooking.
    Have taken notes for the future, many thanks, :Smile:
  8. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,007
    5,235
    Wirral
    I find it helps to spatchcock the chicken or if a small leg of lamb,bone it out and butterfly it.
  9. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,096
    6,655
    Spain for the winter
    I managed to get a 2nd hand one a couple of weeks ago but have only cooked one meal in it so far - fish - it was very nice too. Tried baked spuds but think I had chosen ones far to big as they too ages, ended up cutting them in to wedges, they went nice and crispy though.
