Double Output Solar Charge Controller (1 Viewer)
andy63
4,672
15,017
south shields
None
since 1990
hi, hoping for a bit advice /guidance..
there was a thread last week asking about using the 2nd outlet on a controller to charge batteries and it was established it was most probably a battery load output and not suitable for charging, but someone did say dual output controllers were an option.. ive had a look.......
would like to be able to charge a start battery and feel this would be a good solution , as opposed to say a single output controller and using a voltage sensing relay to link the start battery..
I have noticed that all the double outlet controllers are pwm.. cant find an mppt one...not sure why, but think this may still be the best way to go , ie is a pwm controller a reasonable option... it would be a 10a controller running a 120w panel..
any advice and views appreciated
thanks andy
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Do you want to give priority to your starter battery or your leisure battery. What is most important to you
D
Deleted member 29692
Wouldn't a battery master do the just as well with less messing around?
Techno
Jul 28, 2010
15,475
20,756
May 2010
jesus that was quick andy :)
the leisure would take priority
ta
Just fit a normal regulator and a CBE CSB2 relay about £22 ebay This will only send charge to the starter battery once your leisure has reached 13.6 volts. After reaching 13.6 the relay will pass up to 4 amps max to the starter battery until the leisure drops to 12.6. SO if you put a load on the leisure battery the voltage will immediately drop to 12.6 or less and stop sending precious charge to the starter battery.
For those who need to preserve their starter battery at all costs like when in storage then a Vanbitz battery master is the best option as this will transfer 1.1 amps while ever the starter is half a volt lower than the leisure
andy63
andy63
4,672
15,017
south shields
None
since 1990
thanks for the input andy ..ill have a look at the relay option
andy63
andy63
4,672
15,017
south shields
None
since 1990
No. It trickle charges your engine battery from the leisure battery and keeps it topped up. So whatever your charge source is, EHU, solar etc charges your leisure battery in the normal way and the battery master takes care of your engine battery.
http://shop.motorhomefun.co.uk/product/battery-master/
thanks , ill look at all the options mentioned,
andy
andy63
andy63
4,672
15,017
south shields
None
since 1990
Been working 2 years here, its not rocketscience. Sense 13.6V on leisure then switch on link to starter. When volts drop on leisure cut feed to starter.
it isn't lol...
I have a a dual sensing 120 amp blue sea relay connecting my leisure with the auxiliary vehicle battery and has been working well for years.. the transit dual battery set up isolates the start battery completely when you switch off ignition so that isnt an issuefor me..(the start battery does get charges off a 3 output stirling pro charge 20 when on hook up )
was just wanted to know if a dual output controller might be a better option on another planed installation, and why I couldn't find a dual output mppt type controller...
many thanks for all the replies
ta andy
funflair
19,305
30,071
Guisborough
MORELO palace
since 2012
Hi @andy63 our Votronic does the engine battery as well if required but we have that function built in with the CBE system so I have not got it wired.
It is called Duo and is MPPT it passes 1 amp to the starter battery to the correct voltage.
Got ours from Road Pro.
andy63
andy63
4,672
15,017
south shields
None
since 1990
Once again thank you for the input @funflair and @Techno100 .I'll do the reading ,am inclined towards the cbe csb2 relay you linked to andy... For the batt link
Cheers again ...andy
eddie
8,144
41,181
Taunton Somerset
RV
since 1989
Well I've just donated a Baattery Master is a sort of auction for Haggers who is running a double marathon. Worth a fiver bid to save £65.00 if no one else bids
The original and the best, automatically shuts down if short circuited, over loaded or under voltage, guaranteed 100% fully waterproof, vibration and dust proof and of course has built in automatically resetting fuses (y)
andy63
andy63
4,672
15,017
south shields
None
since 1990
Cheers Eddie. Very generous offer...not sure how you are working your auction..is it a new donation required to enter ..I sponsored Paul when he first mentioned it a few weeks back along with a few others off the forum..
Ta andy
eddie
8,144
41,181
Taunton Somerset
RV
since 1989
Ta andy
Didn't think of that?
@andy63 Thebidding is here but no point in you bidding since you would be fitting it for me :)
Broken Link Removed
Ah, problem solved lol
