double gas connector on my campervan
Discussion in 'Tech/Mech General' started by g4jnw, Apr 3, 2013.
  1. g4jnw
    g4jnw Read Only Funster
    Mar 31, 2013
    36
    10
    Anthorn, Wigton, Cumbria
    am an owner of an old Campervan which was proffesionally converted, in the gas locker there is a red propane connector with a gas tap and there is a tee off this with some orange tubing which also has a tap on, there is no connector on this, could this be for putting butane in?
    There isn't enough room to take 2 cylinders so am somewhat confused. there is at the moment no gas cylinders in.
    never had a choice in my caravan
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,733
    5,964
    Mansfield,Notts
    If you have no room for a second cylinder maybe it's a take of point for an outside BBQ without seeing how its piped up I'm guessing, can you post a pic:thumb:
    Im saying out side because you dont want to be running anything inside the van like a heater or BBQ as you will poison yourself
  3. g4jnw
    Mar 31, 2013
    36
    10
    pics
    hope this is attached ok
  4. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,008
    5,236
    Wirral
    Looks like a home made 'Extenda stay' ie connection for an additional cylinder.
  5. g4jnw
    Mar 31, 2013
    36
    10
    so could i use the other pipe and put a butane connector on? there is no room for 2 bottles but it would give me the choice which one to use, i already have a full 4.5kg bottle i saved from selling my caravan
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,940
    17,606
    YO11 2BD
    if you did you would need a tap in BOTH hoses so when one cylinder is connected you need to isolate the other regulator and visa versa.
    i too reckon its a take off point for a gas BBQ and certainly doesn't look a very professional job to me.
    even i would use double/single lug crimp rings instead of jubilee/hose clips
  7. g4jnw
    Mar 31, 2013
    36
    10
    There is already a tap on both of the tubes, i would connect the orange tube to the new regulator for the butane and will ask for lug crimp rings - can i get them from the same shop as I get the regulator from? or would you suggest just doing away with the Tee section and just making a single tube with a butane regulator on?
