door lock
Discussion in 'Tech/Mech General' started by vana, Mar 23, 2013.
  1. vana
    vana
    Jan 23, 2012
    51
    17
    taunton
    Has anyone got a answer to my problem,which is. I can't lock the habitation door on my swift lifestyle 2008. the door will lock and unlock
    manually but not with the key electronically.
    there is a dull click have checked fuses,the welcome light seems to work OK, The lock just doesn't operate remotely.
    Many Thanks vana:Eek!::Doh:
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    hi either you need a new battery in your key or the door lock solenoid needs servicing/replacing
  3. duane0001
    duane0001 Read Only Funster
    Jan 18, 2013
    629
    389
    East Coast, North Yorks
    or the link between the solenoid and lock has come apart, which is more likely as they tend to be made of plastic nowadays
    • Like it Like it x 1
  4. vana
    vana
    Jan 23, 2012
    51
    17
    taunton
    door lock
    Thanks for the response to the problem, is the solenoid easy to access so i
    can check it out?
    Thanks vana
  5. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,739
    1,331
    living the dream.
    We had trouble like that, a wire had come out within the hab door, fixed by the dealer when I went in for other work, but they had pulled it out when they did the work previously!!!
  6. Thedriver
    Thedriver Funster
    Apr 2, 2011
    62
    47
    south essex Benfleet
    Habitation panels do come off but if you are not confident I would leave to someone who is.
  7. duane0001
    Jan 18, 2013
    629
    389
    The dull click tells me the wires are attached and the solenoid is at least trying to work,
    I still think the plastic connector is broken
    If it is broken you can easily make a metal one
  8. WillH
    WillH Funster
    Feb 9, 2008
    1,742
    1,467
    SW Scotland
    I had this on my 2008 Bessacarr (Swift). Eventually stripped the door panel and found a small coil spring on the lock mechanism was broken. Long fiddly job as I recall.
    Rgds
    Bill
  9. raysalaugh
    raysalaugh Funster
    Oct 28, 2011
    82
    50
    blackburn
    door lock
    just a thought had a similar problem last month,turn key to bottom and door locked,turned key to top and door unlocked, but would not work electronically.
    turned key halfway and removed, worked on fob o k.
  10. Goforit
    Goforit Funster
    Apr 10, 2012
    17
    6
    Warks / Leics border
    Must be the time of year for door lock problems. My remote has just stopped operating the habitation door lock as well. As it still operates the cab doors, I suspect a problem with the habitation door (which I will leave the dealer to sort out under the warranty). But I thought I would try the obvious first and change the battery in the remote, but I cannot see how to get at the battery. It is a 2009 Autosleeper with a Peugeot base vehicle. There is a screw in the recess of the key fob where the metal part of the key goes when folded, but it only seems to turn from a closed lock symbol to an open lock symbol. Any clues how to access the battery?
  11. duane0001
    Jan 18, 2013
    629
    389
    No need to get out the battery
    If it still works the cab doors then the battery is not dead
  12. vana
    vana
    Jan 23, 2012
    51
    17
    taunton
    door lock
    Hi all
    Thanks for your help, I did remove the panel to expose the lock workings
    but could'nt see any problems,so will have to go down the electric wiring fault finding route, I have little experience in this field so I might have to take motorhome somewhere to have it checked out. Have received high prices just to identify problem.( I was hoping for a diy job.)
    Thanks vana
  13. Ingwe
    Ingwe Funster
    Feb 22, 2016
    145
    72
    York
    We have the same problem with our 2012 Bailey. No longer any clunk or click from the habitation door (as it used to). We can lock the cab doors with the fob and the hab door with the key. So no immediate problem. Would be very interested to know how much it is likely to cost on the assumption the solenoid has failed. Although it is supposedly covered by the extended warranty (yes, really) I doubt that I've the stomach (or enough years of life left) for the argument with the warrantor. So will need to pay for it privately. Only a ball park estimate is needed.
  14. Bart
    Bart Funster
    Jun 4, 2016
    1,776
    513
    N.Ireland
    I know you had this problem a few years ago, but can you remember what fixed it , as mine seems exactly the same, will remove panel tomorrow to investigate .
