door fly screens????
Discussion in 'Motorhome Chat' started by jaygee, Jun 10, 2009.
  1. jaygee
    jaygee Funster
    Mar 21, 2009
    1,177
    738
    Harwich, Essex
    I think it would be quite wise to fit some sort of mozzy net to the door of our 1993 hymer campervan.
    Has anyone done a diy fit and could reccommend a make?
    I've seen the Fiamma ones but these seem a bit expensive?
  2. blueraven
    blueraven Read Only Funster
    May 7, 2008
    28
    Stockport, Cheshire
    Mozinet
    I've diy'd ours. Bought a kit for about £6 on ebay which you cut down to size, comes with stcky velcro which attaches all the way around the opening and then you literally stick two pieces to the velcro so that you have an opening in the middle. They also supply the weights for the bottom so that it doesn't blow too much.
    It's okay, but when we had our caravan, I made my own which I have to say fitted better. I took a piece of net curtain (fine weave) with the channel for the elastic at the top, put hooks in the caravan over the inside of the door then measured the length, using wonderweb to create a hem at the bottom. Believe me, I am no seamstress, cannot even sew buttons on very well, but managed to get it to fit better than the kit that we have now. I used some dominoes in the bottom hem to weight it down.
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,322
    5,325
    East Sussex 01-580-881288
    Everythings expensive! Fiamma kiits £21 less your Funsters discount if you phone.
    We do a 2m x 1m mosquito net for £9.78p but I am sure you can buy standard white window net a lot cheaper.:thumb:
    Peter
  4. Bevis on wheels
    Bevis on wheels Read Only Funster
    Jan 18, 2008
    19
    near Sheffield
    door screen
    similarly I got some mozzie netting- charcoal colour so you can see through better- the sort described with weighted string at the bottom. I didn't use the sticky velcro stuff round the door as it's restrictive but tacked a hem in the top and slotted it onto a piece of dowelling. Two cup hooks scewed under the top of the frame hold the dowelling. It has worked through three summers in Greece and several Scottish trips ( those midges get through net curtains!):RollEyes:
  5. davetthedon
    davetthedon Read Only Funster
    Mar 25, 2009
    141
    Malvern, Worcestershire
    Try "The Better Blind Company" Window Blinds | Vertical Blinds | Venetian Blinds | VELUX blinds | Conservatory Blinds. I've just re-fitted my door nets after 7 years hard use, kids, grandkids, mother-in-laws etc. They sell glass-fibre black stuff similar to the original on my Autotrail. Also I've bought the aluminium frames to make retro blinds for home. Simple to make, and surprisingly sturdy (they're German though). They may fit in a camper too. Complete with hinges and catches. Not sure of your door shape, but if you can make the frame square, it shouldn't be a problem.
    ATB
    DaveT
  6. shortfuse
    shortfuse Read Only Funster
    Apr 9, 2008
    38
    Inverness
    I fitted a kit I bought of ebay it's one with overlapping strips about 300mm wide, not up to much as the slightest breeze has them flying all over the place (and the bottom of the strips are weighted ):Sad:
    regards sf
