Don't get caught out!
Discussion in 'Motorhome Chat' started by Jim, Jan 12, 2013.
  1. Jim
    Jim Ringleader
    Jul 19, 2007
    26,998
    79,495
    Sutton on Sea
    If you've used your motorhome recently don't forget to drain it down. Light frosts and you might get away with just emptying your tanks, but if it gets as cold as they are promising in the next few days; then you need to completely drain down.
    1. All the liquids out, Fresh and grey, open those taps and maybe get the last out with a spin round the block. Don't forget the black.
    2. Make sure your water heater is empty.
    3. Run your taps for a little while to empty the pipes (don't damage your pump by running too long)
    4. Don't forget your toilet flush if you have one.
    5. Water filters can catch you out, make sure they are completely empty, or if easily removed, take it out.
    6. Turn the 12v off and then open up all your taps, if they are mixer taps then put them in the mid position.
    7. Remove your shower-head, you be amazed at how much water it might hold
    8. Remove any jars of food or beers, wine and champagne that might crack if they freeze.
    (Lesson learned last year) Remove the fuse to your pump, so when your other half enters the motorhome and flicks the 12v master switch on to do some faffing about and packing, they don't burn out your pump.
    Her.."Ooo what's that smell"
    Me.."You've burned the pump out, the taps are open and the pumps been running dry for the hour you've been in here"
    Her...Oh, i wondered what that buzzing noise was
    Me... :swear:
    • Like it Like it x 15
  2. Philcott
    Philcott Read Only Funster
    Jul 17, 2012
    670
    370
    Bury St Edmunds
    My van is old and the loo system has a seperate container for the blue stuff - when you flush it feeds in - but how do I empty it please?
    Apart from flushing the loo I mean!:Wink:
  3. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,125
    3,541
    Eastbourne East Sussex
    With the locker open there is usually a bit of see through vertical pipe that shows the fluid level. If you pull this out of its clips you can drain most of it, then flush the loo to get the last bit out.
  4. tofo
    tofo Funster
    Oct 1, 2007
    6,691
    6,608
    Kirby cross further from londin
    If its a Thetford when you take the cassette out
    there is a little tube ( grey/ green colour on mine)
    With a little stopper in the end
    Pull the little tube out remove stopper lower till fluid runs
    Drain to a 18 litre container
    That fluid can be stored till next trip time
    [HI]
    Don't forget to put the stopper and cassette back
    And while the cassette is out make sure the kids know
    [/HI]
    Leave the flap open on the toilet bowl save
    You damaging the seals
    Some suggest a little olive oil in first to lubricate the seal
    Then leave it open
    Ours is left open when the van is not in use
    After the cassette has been emptied and flushed of course
    :thumb::thumb::thumb:​
  5. Philcott
    Jul 17, 2012
    670
    370
    Bury St Edmunds
    thank you people! Will go and drain it now - it's cold here already!
  6. Jim
    Jim Ringleader
    Jul 19, 2007
    26,998
    79,495
    Sutton on Sea
    This is when you envy full timers. No draining down for those guys, just turn the heating up a little :BigGrin:
    • Like it Like it x 2
  7. laneside
    laneside Funster
    Aug 14, 2009
    3,609
    5,705
    Oradour sur Vayres
    I just hate to keep rubbing it in but at 5.30 tonight this was our inside temp. with no heating on and the door open
    the 16 degrees is from the sensor under the van :Rofl1::Rofl1:
  8. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,837
    36,276
    Leicestershire
    Typical cheapskate,BLU Tack
  9. Spacerunner
    Spacerunner Read Only Funster
    Apr 7, 2008
    609
    195
    Hampshire
    Why don't you just mix some anti-freeze in with it?
  10. PaulyP
    PaulyP Funster
    Jul 29, 2011
    1,827
    3,190
    Manchester
    Just set up 2 tube heaters on a thermostat control. If the temp drops to zero then they will come on.
  11. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    This is making me want to go out and recheck the van :thumb: but it's too bloody cold out there :BigGrin:
    Terry
  12. Philcott
    Jul 17, 2012
    670
    370
    Bury St Edmunds
    All drained down now, but thanks for the suggestions. Got the de-humidifyer on in there just on a low setting to keep things nice and dry. Will probably have her out again for a drive in a couple of days and just carry what water I need to make tea!
    Roll on Spring!
  13. Jim
    Jim Ringleader
    Jul 19, 2007
    26,998
    79,495
    Sutton on Sea
    Its going to be around minus 10 here tonight. Is there anything in your van that might freeze and make a mess or break something?
  14. ericonabike
    ericonabike Read Only Funster
    Jan 19, 2012
    430
    267
    Leicester
    Have hooked it up to mains on the drive and set Heating control to 'Frost' since November. Reckon it's cost me around £50 in lecky but haven't had to empty it or drain it down and it's been ready to go whenever I wanted [albeit I've only been out for a couple of nights since...]
