DOMETIC TECH TOWER FRIDGE/FREEZER
Discussion in 'Motorhome Chat' started by SteveandDenise, Sep 16, 2014.
  1. SteveandDenise
    SteveandDenise Funster
    Sep 26, 2011
    530
    679
    Spalding LINCS
    We have a Dometic Tech Tower Fridge & Freezer model no. RMDT 8505, which appears to have stopped working.
    All LED lights are on ie. 230 v & 12v and the Gas ignites, but neither the fridge or the freezer are getting cold, on any of the power sources.
    We can not get an engineer out until 6th October and we were planning to be away for the next 2 weeks.
    Anyone got any ideas ?
    S & D
  2. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,939
    West Norfolk
    Have you tryed calling Martins Caravans in Wisbech Steve?
    They seem quite prompt and eager to please there.
  3. SteveandDenise
    Sep 26, 2011
    530
    679
    Spalding LINCS
    We used them for our Auto Trail which was fitted with a Thetford unit. They were very helpful and keen to help I will call them tomorrow.
  4. Red Dragon
    Red Dragon Funster
    Apr 23, 2010
    644
    1,325
    Isle Of Man
    Hi SteveandDenise
    I notice from your Avatar that you have a Rapido,its critical that the level of your van is within 3degrees front and rear and side to side(specially on gas) I had the same problem, and since making sure it was level its been fine.
    HTH.(y)
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,134
    15,070
    Leeds the one up North
    A Dometic service engineer is booked for Lincoln
    Phil from Derwent Technical Services Ltd
  6. Techno
    Jul 28, 2010
    14,134
    15,070
    Have you tried setting it to 230volts and not AES
  7. SteveandDenise
    Sep 26, 2011
    530
    679
    Spalding LINCS
    Yes Steve I have it parked on my drive its level,
    also I have sent an email to Derwent earlier this evening and it is manually switched to 230v.
    I had a look on dometics site to see how absorbtion fridges work but not much info there.
  8. canopus
    canopus Funster Life Member
    Nov 27, 2010
    3,108
    3,481
    Lincolnshire
    Might be the PCB control Board Steve. Have a word with BJ Leisure at Shelford, he's a mine of information.
    • Like Like x 1
  9. Hydrocell
    Hydrocell Funster
    Jun 22, 2012
    176
    112
    Ebbw Vale Gwent
    Hi Steve
    The majority of motorhome and caravans all have Absorption type fridges,
    Which means that they do not have a compressor that controls and move the gasses from the bottom to the top fridge workings.
    A three-way Absorption fridge works by heating the liquids coming from the absorber vessel via a gas burner a 240volt element or a 12volt element, once the liquid gets hot enough then the process begins.
    If you have tried the three elements separately IE Gas 12 Volt & 240 Volt and you have no joy then you’re problem lies else were, check the multi plugs at the back of the fridge via the fridge vet, if they are all making a connection then the problem lies with the main pb board.
    Hope this helps
    Regards
    Ray
    • Like Like x 1
  10. SteveandDenise
    Sep 26, 2011
    530
    679
    Spalding LINCS
    After I set 230v 'manually' and not 'auto' after a few hours (over night) this showed a heater element fault on 230v.
    So now I have switched to gas manually about three hours ago and the temp has dropped a few degrees.
    Once I found some info on how an absorbtion fridge worked, I now realise it is a much slower prosess than a conventional fridge.
    The other thing I had not realised it is still under the 3 year Warranty
    Thank anyway for the advice
  11. Techno
    Jul 28, 2010
    14,134
    15,070
    Yes your supposed to switch it on a good 12 hrs before putting stuff in it
  12. ivorantony
    ivorantony Funster
    Jan 22, 2013
    504
    536
    London SE
    The thermostat knob has a plastic spindle that breaks, you can turn up or down to your hearts content but it isn't moving the thermostat, it's a common problem so worth looking at,
  13. Techno
    Jul 28, 2010
    14,134
    15,070
    No knobs on this fridge
  14. SteveandDenise
    Sep 26, 2011
    530
    679
    Spalding LINCS
    Correct only buttons and lights
