Dometic RMD 8505
Discussion in 'Motorhome Chat' started by Drexxer, Sep 11, 2016.
  1. Drexxer
    Drexxer Funster
    Oct 26, 2014
    287
    306
    Lincolnshire
    Hi all,
    we have just been away to France for a couple of weeks and whilst there we noticed the fridge wasn't cooling properly on hook up, I put it down to being 30 odd + degree's and thought nothing of it,
    After leaving Annecy and on arrival in chamonix we found that the fridge beeped and flashed red / blue on hook up so switched it to gas and all good for the remaining time away.
    Now home and cleared van out I switched fridge off only for it to switch back on a few minutes later and start beeping again???
    Please can anyone point me in the right direction as these fridges seem to have a bit of a reputation
    Thanks Andy
  2. ambulancekidd
    ambulancekidd Funster
    Sep 23, 2014
    865
    2,131
    Ayrshire Scotland
    Sounds like the mains voltage element in your fridge is on the way out. A common problem if they're used for longish periods. Elements are cheap to buy, but labour costs to replace them are high. If your halfway competent as a DIY sort then its an easy job to do at home.
    Just as a for instance look up E bay number
    201648565927
    • Like it Like it x 1
  3. Drexxer
    Drexxer Funster
    Oct 26, 2014
    287
    306
    Lincolnshire
    Now it's just flashing through the gas / 12 / 240 / AES readouts without stopping!
    Andy
  4. ambulancekidd
    Sep 23, 2014
    865
    2,131
    Ayrshire Scotland
    If it's on "Auto" & plugged into the mains, it'll be having a hissy fit. Try unplugging from the mains, engine off & see if it'll go back over to gas. Hopefully it'll settle down & prove that there's a mains element fault.
  5. Drexxer
    Drexxer Funster
    Oct 26, 2014
    287
    306
    Lincolnshire
    Thanks AK, unplugged but still doing it, totally unable to switch off now?
    Andy
  6. ambulancekidd
    Sep 23, 2014
    865
    2,131
    Ayrshire Scotland
    I should imagine that there's a reset switch somewhere on the fridge, if not it's time to isolate the vehicle totally, disconnect the battery for 20minutes or so & see what happens when you power it back up.
  7. Drexxer
    Drexxer Funster
    Oct 26, 2014
    287
    306
    Lincolnshire
    Just reconnected battery and went onto gas then AES, now back to flashing between the 4 readouts
    Andy
  8. BwB
    BwB Funster Life Member
    Apr 3, 2011
    613
    567
    Suffolk UK
    Is the selector button stuck in?
  9. ambulancekidd
    Sep 23, 2014
    865
    2,131
    Ayrshire Scotland
    I'm not quite sure why it'l be doing that, but I still have the mains element as chief culprit. It might need to be looked at by your local dealer, but lets wait to see what other forum members think? There's a huge wealth of experience on here.
  10. Drexxer
    Drexxer Funster
    Oct 26, 2014
    287
    306
    Lincolnshire
    Does not appear to be, pushes in and releases ok
    Andy
  11. BwB
    Apr 3, 2011
    613
    567
    Suffolk UK
    I asked because it sounds like my previous fridge which had an AES selector button. If you held the button down it just cycled through the options. They can do this if the get wet/damp too (at the button) so maybe a bit of dirt or water? Just thinking out loud :)
  12. Drexxer
    Drexxer Funster
    Oct 26, 2014
    287
    306
    Lincolnshire
    Just took it all apart and used my airline to make sure no water / damp in there,
    shut fridge door and now it has settled on 240v though cannot change it!, still flashing red / blue also
    Andy
  13. SandraL
    SandraL Funster
    Jan 24, 2012
    329
    163
    Somerset
    If you google "rmd 8505 user manual" you can find the dometic manual. Page 22 ish explains what the lights mean. Sorry dont know how to paste the url using ths tablet. It was a dometic site it came from. Good luck !
  14. SandraL
    SandraL Funster
    Jan 24, 2012
    329
    163
    Somerset
    This might be easier, look in the resources section, theres a download for 8 series fridges. I cant download on this tablet but hope it has info you need.
  15. Drexxer
    Drexxer Funster
    Oct 26, 2014
    287
    306
    Lincolnshire
    Seems to have settled down into a flashing AES / GAS , still not able to turn fridge on or off
    Andy
  16. BwB
    Apr 3, 2011
    613
    567
    Suffolk UK
    Think I might be inclined to power it down completely for a few hours and then try again. A sort of "reboot" in case the controller board electronics are having a turn.
    You seem to be making a bit of progress with it though. Fingers crossed.
  17. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,238
    15,222
    Leeds the one up North
    Best remedy is to ditch the existing control boards, front and rear and change to a 7000 series board. It's less tech but reliable since I did mine.
  18. Drexxer
    Drexxer Funster
    Oct 26, 2014
    287
    306
    Lincolnshire
    Don't suppose your ever passing this way Andy?
