Dometic RM7270 help (1 Viewer)
Petest
199
185
Uk
New convert
HI
Our fridge won't light on gas.
Works fine on mains.
Does any one know if the piezo lighter button has a replaceable battery?
I'm thinking I'll try and eliminate the cheapest options first.
I plan on pulling it out and trying to clean and blow out the burner to see if that helps.
Any advice?
P.S. The youtube service video should be a great help to me
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Hi, can you hear a "clicking" sound when you turn it onto gas? if so the igniter is trying to spark, if not then igniter obviously not working. I think they are usually powered by 12v but not certain.
Someone will be along soon to give you a more definitive answer.
Hope this helps (a bit!)
Cheers, Dave(y)
Petest
Petest
199
185
Uk
New convert
Cheers Dave.
It has a push button ignition. Turn to gas setting, push and hold temp dial in, press ignition button (which then clicks).
Mar 26, 2009
8,158
11,215
Yr Wyddgrug
Hymer B678DL
Since 2009
I've had a similar problem where the selector dial doesn't seem to register correctly in the GAS position and doesn't ignite. Moving it back to 240v and then back to GAS seems to cure the problem. Don't know if this is your problem but worth a try.
kevin915
5
starburst
I have. RM7270 fridge very unreliable ignition on gas no spark any suggestions?
kevin915
5
starburst
Hi, I can see the gas jet viewed through the circular window inside the fridge but as reported the ignition spark is very occasional sometimes if I leave it for a while then I get a spark and it lights. so not a problem with the gas reaching the fridge.
Reactions: Les
kevin915
5
starburst
Can you see the sparker and gas jet
Jan 28, 2008
10,111
18,365
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
poor spark is usually a sign that the burner needs cleaning especially the earth terminals
Jan 8, 2013
8,490
11,526
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Its a common problem with gas fridges. The gas jet is very small and easily blocked. The sparker electrode could need cleaning and adjusting. You need to get to it, it all need a service.
kevin915
5
starburst
Ok many thanks, it’s got the piezo button so not the continuous spark until it lights it depends on one button press one spark so everything has to work around the ignition/gas jet for it to work pre 2005!
Mar 11, 2013
1,280
1,678
Gillingham
coachbuilt
since 2005
You can buy an electric replacement for the push button. It is easy to change the push for the battery powered device from the front of the fridge. Remove the two knobs and two screws and the plastic surround can be removed.
Mar 11, 2013
1,280
1,678
Gillingham
coachbuilt
since 2005
This is the replacement part. I changed mine and this worked well. The battery is in the silver cap. As suggested the selector switch can also be a problem.
