dometic min-max dial (1 Viewer)
Oct 29, 2012
887
1,045
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
Greetings oh wise ones.
My fridge freezer (dometic 7655l) min-max dial doesn't seem to be doing anything when turned.:Sad: The minimum light is on but none of the others will come on as the dial is turned.I have put a thermometer in the freezer to see what temp. its at but thought I would consult the oracle before delving any deeper. Can you replace just the dial or is it the whole control panel and where is the best place for spares?
Your thoughts would be welcome.
C
cranky
Oct 29, 2012
887
1,045
essex
Rapido 9090df
update.after much googling decided it could be the shaft on the control knob broken but will leave it as is till after the weekend.
The freezer is running at -8 degrees and the fridge at +8.Is that about right for minimum setting?
BTW found these part suppliers if its any use http://www.dometicapproved.co.uk/spareparts.aspx?p=spareretail
43,329
49,441
in a domestic situation a freezer should be -18 and a fridge +5.
i would see what the thermometer reads after a few hours.
it could the lights come on when the desired temp is reached...not when you turn the dial.
sort of informing you the temp is at the desired level
an absorption fridge set to max will only cool to around 20deg below ambient temperature which is why some folks fit a small fan in the fridge vent....moving air is cooler than static air so removes more heat from the fridge.
ie: 30 deg outside....10 deg in the.fridge
or 10deg outside...you need to turn the fridge down or risk freezing as it could be -10deg
cranky
Oct 29, 2012
887
1,045
essex
Rapido 9090df
Cheers PJ. The lights should come on when you turn the dial so I am assuming the shaft is broken. It doesnt look to difficult but we are away for the weekend so will have a go at it next week.Freezer is reading -9 and fridge +6 so that will do for now. It looks like it is stuck on minimum. Its enough for the beer::bigsmile:
cranky
Oct 29, 2012
887
1,045
essex
Rapido 9090df
just an update. Finally got to dismantle front of control panel and confirmed it was the shaft (that the control knob pushes onto) that had broken. New part ordered from Dometic Centre Online Shop £4.73 Job done.:Smile:
canopus
6,139
10,255
rural Lincolnshire
Carado CV640 Pro
Since 2010
We had the same problem on a different model fridge - shaft was broken where it marries up to a tiny potentiometer on the pcb and the pcb was goosed also.
Cost £175 for new pcb :Angry:
cranky
Oct 29, 2012
887
1,045
essex
Rapido 9090df
Ouch! and there's me complaining about the 5 squids for a little plastic shaft!!
