Dometic fridgefreezer - thermostat? (1 Viewer)
gowboy
43
7
Ludlow
Fiat/Benimar 7000 A Top
two
Stab in the dark: Dometic RM7505AES fridge freezer on constant min. temp - causing fins to freeze up, food to frost - no matter how thermostat is set. Unit been turned off, thoroughly defrosted, still behaving same way.
Been on Leisuredirect to see parts guide, spoken to ELUSIVE Dometic agent, think whole front thermo/control unit may need replacing, expecting repair £150+ (part alone).....just wondering if there is an easy fix i am missing?? I know zip about gas, but happy to tinker if there is something obvious that anyone can suggest....
Can you help?
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
I am sure D Newell would no doubt know as he is an expert on these matters
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Just a thought on some Dometic models the plastic spindle between the control knob and the rehostat thingy breaks so you move the knob but it does not move the stat always worth checking:thumb:
TheBig1
17,630
43,252
this could be the thermistor in the control (heat controlled resistor) or the internal thermocouple that clips to the fins in the back of the fridge compartment.
have seen the same problem cured by just emptying fridge and resecuring the probe with the fin clips. It had dropped off and was below the fins
TheBig1
17,630
43,252
as its an AES model, the temperature control is electronic I believe for the whole auto energy source range
G
gowboy
43
7
Ludlow
two
thanks will check this.... I have been back to my van today to have a poke around, and doh noticed a "Climate Control" switch underneath the control panel - this was in the "off" position - so on the poss that i caught it and turned it off some weeks ago whilst cleaning I have turned this "on" and restarted the unit - will check tomorrow to see if this is the underlying temp. issue????!!!! Any thoughts? Interesting that the original manual does not mention it, and that the Dometic engineer didn't ask me about it.... I wait with bated breath.....
G
gowboy
43
7
Ludlow
two
Resolved....
as per my last comment, "problem" resolved - thanks for your input, it's a learning curve!
