Dometic Fridge (1 Viewer)
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
Hi all,
My Dometic fridge is not getting cold. I have set it to the coldest setting and left it for 24 hours. Still not cold. Having removed the vent I can feel the heat exchanger is quite warm, so the fridge is trying to cool. Can the fridge be re-gassed? Does this sound like it could be the problem. Does anyone know of an engineer in the Bradford, Skipton area?
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Should be getting noticeably cold within the hour.
Mine is two years old this august and finally getting a new cooling unit fitted this week as it has always been on maximum cooling and never achieved the desired effect.
Dometic engineers are scarce for warranty issues. I am using JMR caravan services under warranty. They cover our area
Techno
Jul 28, 2010
15,475
20,756
May 2010
Are you running it on gas? and is it the same on mains?
glenn2926
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
Hi Techno,
Tried it on gas and 240 doesn't seem to make any difference.
43,323
49,428
There is no means to regass, but a fridge engineer may be able to install filling valves.
if it has leaked there should be a yellow powdery/crystaline substance behind the inspection vent of the fridge
Another "favourite" trick is remove the fridge and turn upside down for a few hours.
this has the effect of remixing the gas and carrier medium which seperate and settle at the bottom of the coolant pipework.
Time consuming but worth a try before spending big bucks
glenn2926
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
Thanks for the replies so far. I think it may be another trip back to the dealer I bought it from. I have only had the Motorhome for a month and it has already been back once. They did sort out the problem last time though. I have not used it yet. This is starting to become very annoying.
