magicsurfbus
I'm beginning to suspect something's wrong with the 12v circuit in our Dometic fridge, which is about 10 years old.
The green front panel light goes on for 12v, so power's getting to it, but the LCD temperature sensor I've fitted shows it getting slowly warmer when we're driving. The thermostat is usually set to the middle setting or slightly cooler.
No problem on 230v or gas that I can see, just on 12v.
Am I right in thinking the 12v and 230v elements are separate components? Also wondering about if there's a loose or corroded connection.
If the leisure battery was packing up could this prevent power going to the fridge in 12v mode? The battery seems OK but it is getting on a bit.
Any pointers gratefully received here.
