Dometic fridge and freezer playing up
Discussion in 'Carthargo' started by Dorset Diver, May 12, 2016.
  1. Dorset Diver
    Dorset Diver Funster
    Dec 23, 2014
    370
    187
    Somerset
    Currently in France (Concarneau).
    Carthago Chic C-Line.
    Fridge / freezer working well until last night when we arrived here. Worked at first then decided that it would not operate off the 240V. Lots of relay type clicking from the innards and eventually it switched to gas. I have now switched from Auto fuel selection to gas as we need to keep stuff cold / frozen. Never had a problem before and wondered if it could be because the site may have reversed polarity but I have no means of checking this; everything else is working fine. Site is at least 10A possibly 16A (staff don't seem to know :rolleyes:).
    I have no plans or tools for a deep maintenance job but wondered if any of you good people may have some insight.
  2. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    5,830
    10,804
    East Sussex
    We've got the same van and had a similar problem once before
    It could be low voltage on the site
    It does mention this as a possible cause in the handbook
    Like you we switched to gas and when we plugged in next time (at another site) all worked fine
  3. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,962
    2,788
    Kendal, Cumbria
    It most definitely cannot be line / neutral reversed.
  4. rogher
    rogher Funster
    Aug 4, 2011
    489
    218
    West Midlands
    Sounds like low mains voltage, DD. Is your location full of others using EHU? You could try knocking the Alde off electric. I suggest you try your fridge on mains again at another location. If it’s fine then, clearly it was something to do with the current supply (pun not intended).
  5. Dorset Diver
    Dec 23, 2014
    370
    187
    Somerset
    Hello @rogher . I did check it with the Alde off, not that it was really on as the weather is good so we don't need the heating only a bit of hot water, however, it made no difference. Now that it has been mentioned I do suspect a supply problem although the site is only about one third full. Time will tell ;).
  6. Dorset Diver
    Dec 23, 2014
    370
    187
    Somerset
    Hello @Robert Clark . Thanks for the comment, seems very likely. I guess we will find out when we next use another site.
  7. Robert Clark
    Jul 12, 2014
    5,830
    10,804
    East Sussex
    If you have a problem with your coffee machine holder dropping down, let me know as I've got a solution for that
  8. sallylillian
    sallylillian Funster Life Member
    Oct 29, 2011
    860
    534
    Falmouth, Cornwall
    If you look at the breaker and it's not ancient it will have c6 c10 c16 or another number, respectively 6 amp 10 amp 16amp. You get the principle?
  9. Dorset Diver
    Dec 23, 2014
    370
    187
    Somerset
    I get the principle thanks but on this site they are locked away :( .
  10. icantremember
    icantremember Funster
    Sep 2, 2010
    5,225
    7,316
    Nr Watton in Norfolk
    As said above almost certainly a low voltage supply .... we had exactly the same symptoms on another French site and when I put a meter on it only had about 180v.
    Best not to use the electric as the continual auto switching can cause damage ... it may have been coincidental but our 240v fridge element failed shortly afterwards.
    • Informative Informative x 1
  11. Dorset Diver
    Dec 23, 2014
    370
    187
    Somerset
    Mine did self deploy on the trip to Southdown's for its first check-over and they changed the gas strut. Since then it has behaved, however, it would be good to know a fix, or does it involve some form of adhesive? :LOL:.
  12. Robert Clark
    Jul 12, 2014
    5,830
    10,804
    East Sussex
    Ours kept dropping down on our recent trip to Italy - and got worse as we went along. It's a bad design as it relies purely on a piston to support the weight of a Nespresso Pod machine.
    So I fixed it with a chrome Sash Window Catch
    View from below - which slides out when travelling
    [​IMG]
    [​IMG]
    And retracts when needed
    [​IMG]
    Mrs C gave me 5 stars for innovation !
  13. Dorset Diver
    Dec 23, 2014
    370
    187
    Somerset
    Very neat. I will keep that one up my sleeve, thanks.
    Have you had any trouble with the blinds. Ours are sometimes very reluctant to clip up and on some the side guides have pooped out and they are a bugger to replace.
  14. Robert Clark
    Jul 12, 2014
    5,830
    10,804
    East Sussex
    The slide guides have been a minor issue - whenever they pop off I fix them with super glue.
    When raising the blind I find it useful to tilt the blind towards me slightly - seems to locate better that way.
    Have you got a steel plate surrounding the TV / radio aerial on the roof?
    Ours was was painted steel and has started rusting and is being replaced with an aluminium one.
    Also our pop up TV is a bit 'wonky '. Needs new runners - all being done at first service.
    • Useful Useful x 1
  15. Dorset Diver
    Dec 23, 2014
    370
    187
    Somerset
    I don't have a TV aerial as we have a sat dish. I'm told there is a "bumper" TV aerial but it never seems to work well so the dish get used. I have not really looked up top so can't comment about the radio aerial.
    Pop up TV is as you say a bit wonky. It is also stiff to raise but does the job, but I will check to see if it is really okay.
    Generally most things seem to be okay but water can seep out around the red inspection cover of the lower fresh water tank when it is under pressure from the extra 60ltrs in the upper tank.
  16. sallylillian
    Oct 29, 2011
    860
    534
    Falmouth, Cornwall
    So ask them to open the cabinet! And look! They will appreciate the education!
  17. Dorset Diver
    Dec 23, 2014
    370
    187
    Somerset
    Can't be arsed, to many other more interesting thing to be doing.
  18. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,510
    12,658
    Bolsover, Derbyshire
    If your lead is long enough or you have another you could try another post, we had issues in Spain last year, controller said no power site said post was good and had been used that week, when I measured voltage it was only 80V, had 2 leads so connected further down site all then OK
    as you say though, better things to worry about, have another drink move to another site tomorrow try again, I am with the majority above, pretty sure the problem will go, don't forget to return to AES or auto setting (y)
    • Useful Useful x 1
  19. sallylillian
    Oct 29, 2011
    860
    534
    Falmouth, Cornwall
    Thank you!
  20. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,510
    12,658
    I don't really know what he would gain by checking the switch rating, it isn't tripping just not working right o_O
    or am I missing something
Similar Threads
  1. Dorset Diver
    39
    1,377
