bevnsimon
hi does anyone have any experience with dometic rm7505 fridge/frezzers mine has an intermittent fault. kind regards bev
fridge not working on gas first thing to check is blocked injector you tube will show you how to check itHello, Im looking for additional information on the Ventil GV100 gas valve for a RM 7551 Dometic fridge. It works on mains and 12v. The igniter unit I am suspecting is ok as the igniter sparks away but no gas ever lights. It times out then stops and flashes after pre set ignition time. I have tried to light with a barbecue lighter while the ignition cycle was active.The Dometic diagram gives no details of voltage to open the valve. I was assuning this was 12v but I have come across one on ebay that states the valve operates on 1.5v? Any help for additional info on the valve ie resistance of coil and if 1.5v is the operating voltage. I will attempt to troubleshoot t the weekend. Thanks Stuart
