Domestic fridge not working on 12V (1 Viewer)
Aalpha1
4
Fife
Van conversion A class
newbie
Hi I was wondering if anyone can give me advice on where the fridge fuse for the 12V in the engine compartment would be fitted on a Ducato base. I thought it would be obvious? The dealer I bought it from couldn't quickly identify it and so have booked it in again so they can trace the cable back. However if I knew where I'd do it myself. To summarize, 240V fine, gas is ok if I ignite with 240v, but no interior light on gas or when trying with 12V and no power when switched to 12V?
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Perhaps I am stating the obvious but they all only work on 12 volt when the engine is running. Sorry if you already realised this.
Jul 24, 2010
535
4,143
Planet Earth (I think)
not long enough
Sorry, I can't help but I am interested in any answers as my Dometic fridge has just ceased working on 12 v too. Perfectly fine on gas and electric hook up. Currently in France and using aires and travelling a lot. Really need the fridge to work on 12V.
Thank you,
Lorraine x
A
Aalpha1
4
Fife
newbie
Hi Laneside this is my problem, which I should have made clearer, I have no power to the fridge on 12V when the engine is running. My understanding of the circuit is there will be a fuse probably in the engine compartment I wondered if anyone could give a location where to look. I was surprised that my garage (a motorhome dealer) couldn't identify it straight away.:Sad:
A
Aalpha1
4
Fife
newbie
Hi, its a Lunar Champ early 2006 model. On a Ducato 2.8l chassis,
Cheers.
june123
350
134
Staffs
Burstner A class 3 berth
since 2004 caravans before that
we have a Burstner on a Ducato base
Our fusebox is under the passenger seat
A
Aalpha1
4
Fife
newbie
Thanks for that, I'll check when I get home. I did look in both fuse boxes located each side of the dash (which I thought would be the obvious place), so hopefully there's an additional one there.
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Hi have a look for relay/relays and fuses near to the battery or alternator
terry
GJH
29,450
38,827
None, now sold
2006 to 2022
When I was looking for a wiring diagram for our son's old camper a few weeks ago the closest I found had the fuse between the starter battery and the fridge relay (which is also connected to the alternator). It may be worth checking if there is an in line fuse somewhere near the relay.
43,323
49,427
I could have my wires crossed :Doh: but the gas igniter PCB ONLY works on 12v.....not 230v mains.
on 230v hookup it will switch to run on mains supply.
Nov 26, 2007
148
49
Exeter
c class
Since 2006
Dometic Fridge
Hi,
Mine is under the bonnet beside the battery, i know as i have had to install a cooling unit, and when doing this i the 12v wires touched a blow the fuse.
I have a luner Roadstar on a fiat ducato 06 reg.
Ian
