Does LPG burn hotter than Calor Gas?
Discussion in 'Heating and Air-Conditioning' started by Jo662, Jan 31, 2016.
  1. Jo662
    Jo662 Funster
    May 7, 2011
    798
    510
    East anglia
    We had gaslow fitted last week,and this morning we used the Motorhome for the first time to cook
    breakfast and have the heating on.:)
    My question is does Lpg burn better than Calor gas as the Motorhome seemed to heat up quicker and
    I cooked breakfast alot quicker than I normally do!:)
    Or is it just my imagination?o_O
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,941
    I've never noticed it. Mind you we used Calor in our first van and LPG in the current one so not a true comparison.
    I believe butane burns hotter than propane as toast does better on one of those stand up wire toasters on a butane hob.
  3. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,143
    544
    Calor gas is LPG?
    • Like Like x 3
  4. GJH
    Aug 20, 2007
    27,346
    34,941
    I think what the OP is querying is the potential for a different mix between Calor and Autogas, which might make one burn hotter.
    • Like Like x 2
    • Thanks Thanks x 1
  5. Jo662
    Jo662 Funster
    May 7, 2011
    798
    510
    East anglia
    Ok,must just be better out of the pumps in garages than what calor supply in there bottles then! lol
  6. Jo662
    Jo662 Funster
    May 7, 2011
    798
    510
    East anglia
    Yes thats exactly what Im asking!:)
  7. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    6,009
    11,458
    East Sussex
  8. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,063
    6,065
    West Sussex
    Calor can be either Butane (blue bottle) or propane (red bottle), Propane used to run hotter as it was run at higher pressure. Now we run both at 30 mb Butane has a higher calorific value therefore it will run hotter.
    However we need to take temperature into consideration, Propane continues to gas of down to -40, Butane stops gassing off at 0 deg., in practice Butane is almost unusable below about 5 deg and in practice flow rate starts to drop around 10 deg, so at this time of year Propane will out perform Butane.
    Autogas in the UK is 100% other countries it is a Butane/Propane mix depending on time of year.
    • Informative Informative x 4
    • Like Like x 1
  9. Zigisla
    Zigisla Funster
    Oct 24, 2015
    1,107
    1,295
    Fareham, Hants
    Would this be the reverse then. As Autogas is propane?
  10. Jo662
    Jo662 Funster
    May 7, 2011
    798
    510
    East anglia
    Ok,well mines hotter anyway!:rofl:
    • Informative Informative x 1
  11. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,143
    544
    Lucky you.
    • Like Like x 1
  12. Steve
    Steve Funster Life Member
    May 8, 2013
    1,571
    1,850
    Compton Berkshire
    For info. calor gas sell both propane and butane and autogas. but autogas can be a mix of both. It is worth noting that a lot of people are using butane regulators 28-30mb with propane. Propane regs and normaly 38mb. So if you please check that the reg. is the right one. It is also quite possible to have a propane reg 38mb on butane. This will give out more heat. but may course problems
    • Thanks Thanks x 1
  13. GJH
    Aug 20, 2007
    27,346
    34,941
    I think @Lenny HB explained it better than I can :)
    • Like Like x 1
  14. ubuntu1
    ubuntu1 Read Only Funster
    Feb 13, 2008
    155
    44
    Derbyshire
    Since 2004 all motorhomes have to run at 30mbar across the whole of Europe. As described above autogas is just a butane/propane mix and Calor is either propane (red cylinder) or butane (blue cylinder). The calorific values differ but for most of the year there is little practical difference. In winter you need propane.
    • Thanks Thanks x 1
  15. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,816
    1,677
    Cornwall
    Just for info.
    I have in the past used a cylinder fitted with a Butane Reg when the cylinder had propane in it.(Don't Ask)
    It seemed to make no difference whatsoever despite the supposed difference in assumed pressures.
    I would add that this was on an outside gas hob being used outdoors.
  16. denisejoe
    denisejoe Funster Life Member
    Aug 6, 2014
    1,219
    891
    Isle of Sheppy
    For the last 40 years we've been using Butane and Propane Calor Gas cylinders and as far as I'm aware there is no way you can run a butane cylinder on a propane regulator and vice versa.
    Joe
  17. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,063
    6,065
    West Sussex
    Why not, providing you have adaptors, we all now run both at 30mb, a bit low for propane & slightly higher than the old butane regulatrs.
    • Like Like x 1
