does anyone out there.....
Discussion in 'Tech/Mech General' started by pappajohn, Jan 21, 2011.
  1. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    ....fully understand, and can test & repair, electronics ?
    i have a 20amp statpower (Xantrex) american charger which appears to have stopped working.
    its not a current model so nowt on the web.
    its been in the garage since removing it from the RV last november.
    plugged it in to charge a car battery today and, without load, it light up showing it detected 'no battery'.
    connected the battery, switched back on and NOWT ! no lights, no output.
    checked the battery and it is very dead....Zero volts.
    should have checked that first :Doh:
    3 internal fuses..rev polarity, overload, short circuit....checked with multimeter and all ok.
    230v getting to input .
    may have been damp inside.
    what i need is a techy to have a look at it and see if its repairable.
    worth around £230 so dont want to scrap it.
    anyone going to newark who could take it home and have a look please?
  2. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,068
    DERBYSHIRE
    Before saying it is the charger try it on a battery that has some charge in it as it may not operate on a totally flat battery just a thought
  3. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    worth a try i suppose but it did light up with no battery...sequence of leds indicate various problems...over/under voltage, no battery etc...but now it does nothing. :Sad:
  4. dealgan
    dealgan Read Only Funster
    Oct 23, 2007
    137
    Donegal, Ireland
    That may be the key. Is it an SMPS (switch mode power supply) or an old fashioned (but arguably better) linear power supply with a transformer, etc ?
    Judging by it having indicators of fault conditions, I'd guess its a switch-mode, in which case I am of no further use !
    Good luck.
  5. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    yep...just electronics and two very small (20/25mm sq) transformers towards the back end of the board.
  6. hilldweller
    Dec 5, 2008
    26,903
    25,759
    Macclesfield
    That's a switcher. Good when they work, only the maker stands much of a chance of repairing one. They are absolutely lethal things, rectified mains putting 340V DC on the pcb so a real specialists repair.
  7. Chani
    Chani Read Only Funster
    Mar 26, 2009
    125
    7
    Somerset
    Switched-mode power supply repair? :imoutahere:
  8. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    I cannot advise on that charger, as I have never met one in person - however, I did have a charger once that had a very similar quirk.
    If cold or damp - it never wanted to play. Leave inside by a rad for an hour to warm and dry out and it would work perfectly. I did replace it in the end! lol!
    Might be worth trying that.
  9. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    its been in the house all last night and today and as a belt & braces exersize i got the cover off and got hair drier on it as well.
    on the input side is a small glass 230v fuse in very close proximity to a heavy copper wire coil.....bit like a ferite ring.
    so close in fact, it was arcing across from the 230v fuse end to this coil when i plugged in the power plug.
    reckon its dead....what a waste. :Sad:
