Does anyone have any knowlege/experience of internet via satellite systems? (1 Viewer)
Jul 2, 2011
953
492
UK
Swift Kon Tiki Tag, 2007.
Newbie
I know they are expensive, quoted £3500 to fit with 85cm dish and data packages vary based on data allowance. I am aware of the various other much cheaper options available via various devices and wifi.
So putting aside the cost, does anyone have any knowledge and/or experience of how well they actually work both at home and abroad?
Talking to a few dealers at NEC, it seems that you have to purchase the equipment and data package separately. That could be a problem, you could be sat on a site in Spain for instance, no internet and both suppliers (equipment and data) blaming each other for the problem.
Has anyone ever seen it in action?
Steve
mikeman
40
9
Wiltshire
Fifth Wheel kountrylite
Started in VW Kombi in 1971
Robert Jackson was talking to me last year about it but I thought it was a bit expensive at the time. However now with the fact that we will be losing most of the british TV channels in Spain it will be worth a second look.
Mike
Jersey joe
56
18
Jersey c I
Since 2012
Satellite systems
I had one of these all singing all dancing Internet satellite systems fitted to my new van 12 months ago by the factory at great cost.
12 months on it has never been used,for two reasons:-
1 -the huge cost of subscribing to the provider.
2-I have never been in a position where I have needed it. Have 3g IPad and Wifi frequently available.
Anybody interested in buying it ! !
Apr 21, 2009
546
34,928
East Cowes, PO32 6RU
Caravan
Caravan since 1970, motorhome or RV since 1999 then back to a caravan in 2017.
I looked at a system by Avonline and they thought I could have the gear in the RV and, when parked at home, use it in the house via WiFi.
This meant that I could save the cost of my current broadband as well as getting rid of the landline. There was even a way of getting SKY via the same dish!
At a quoted 20Mbps I was getting keen until I noticed that they broke the UK into 4 or 5 'footprints' and charged £25 every time you moved from one to another. This meant that my normal trip could cost an additional £75 to £100 by the time I got the connection reset back at home.
At this point I decided that the CC and C&CC internet fees are not too bad and, even if I use my mobile 'phone as a modem, I could not use that amount of money - shame though it looked good until I found that snag.
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
Mike
Interesting as I have never had a problem to date getting the UK channels on a 85cm dish........... and it has never been confirmed that we will loose the channels ( yes I know 5USA,5* have gone ), but BBC1 etc are fine.
John
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
oddly i have looked into this and found the equipment really expensive although you can get it for your house for as little as £299 yet just because its mounted on a flashy plate with a couple of motors they want nearly £3000 off you.
mention motorhome or yacht and the pound signs just roll on and on.
Broken Link Removed
get one of the house ones and mount it on a tripod like we do with the portable dishes and save £2700 for data
Nov 14, 2009
425
252
normandy
c class
16 years
hi, i had a normal oyster 85 and built my own system. hardware from astra 2 connect (£299) and made a €20 aluminium bracket. i get 6mb download speed and 256 kb upload, 2 gb data p/month but unlimited albeit slow after that at no extra charge for £24.99 p/month from beyondsl. footprint is pretty good covers most of spain (using it here from denia) but not portugal , all scandinavia, and nearly all of eastern europe over to turkey . i carry a bigger dish as well and have used it (on a tripod) in northern morocco too. best thing is i can watch tv and have the internet at the same time from 2 separate satellites. all the best sean
nickbox
Staffs
Hi Seanoo
How did you work out the alignment on the bracket - presume your TV LNB is still being used by the oyster for the auto align? I'm trying something similar with a mobilsat dish and getting about 15db signal off 23.5 but no better.... The Astra2Connect lnb is central like yours with the TV offset.
Nick
Encantador
Jul 2, 2011
953
492
UK
Newbie
Thanks for the replies.
Not sure I could be bothered with lugging a portable set-up around and having to keep putting it out lining it up etc. Would be a pain if you wanted to get online while just stopping for a break/lunch etc.
So it seems a standard roof mounted 85cm dish with a £300 internet gizmo would be the way to go.
Steve
oldun
747
162
St Neots
VW Campervan
Since 2001
Very slow - rather like dial-up - well it was on board the two cruise liners I have stayed on.
eddie
8,144
41,181
Taunton Somerset
RV
since 1989
Fitted loads to answer your first question.
IP Copter left many people with ALDEN Systems in difficulty when they changed their service over to Astra2connect
This resulted in a lot of bad feeling. The Oyster system is good but ultimately low volume so expensive, as it the data use age which of course is out of Oysters control.
Unless Internet access is critical we normally try to steer our us tomes away from it.
Regards
Eddie
Nov 14, 2009
425
252
normandy
c class
16 years
mines not slow oldun , you do have a small delay when you click on a webpage (1 second) and then i get my full 6mb download speed. i can upgrade to 10mb but 6 is fast enough for what i do. cheers sean
Nov 14, 2009
425
252
normandy
c class
16 years
Hi Seanoo
Nick
hi nick , sorry for the delay !
i manually aligned the dish on 23.5 with my meter then placed the tv lnb roughly in the right place on the bracket i made then attached the meter to this and adjusted until i got full strength. the tv lnb will need to be roughly 30mm higher than the ilnb. give me a pm if you need any more info, all the best sean
phodetheus
248
237
Full timer
Coach Built
3 months
Regards
Eddie
Eddie has the situation changed much in the 2 years since this post?
I am looking for a solution for high use internet coverage throughout all of Europe including the furtherest tip of Spain and Portugal.
Gary & Ann
eddie
8,144
41,181
Taunton Somerset
RV
since 1989
Gary & Ann
Yes, the market has opened up and the Oyster system is no longer sold "locked" to IPCopter to allow you to shop around for the best deals..
Because of this we are seeing more people paying the extra to have the Internet option when we install their Oyster
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
I have not used that system myself but I was talking to Old Mo last year in Portugal and he had one on the roof, give him a PM he might be able to advise. Pete
