I note that a lot of the new vans come only with a tin of Glup and a silly compressor, Well I have a spare wheel on my van and BOY am I glad I had it. The valve on the rear offside split open and a flat tyre happened whilst I was driving at speed on the way to Stafford on Friday. I noticed it when I stopped at Aldi in Towcester and then tried to pump it up using a garage pump next door. The type you stick 50 p in and set the pressure, It did nothing at all as it kept going to 26 psi and letting out most of what was left. in the end I heard the air coming out whist moving the valve. Out came the spare from under the van. I got plastered in dirt but at least I had a tyre with air in it. Struggled and farted around and got it on with its mate, but the valve was sha===ged so I later parked up and then went to a small garage who changed it for a £5 but I suspect the tyre is no good as it was very hot, so another tyre is needed so that I can match it to the unused spare that is on there now.
NO GLUP on Earth is going to save you when a valve goes. so I advise everyone to get a spare from a scrapyard or some other source.
You will not regret it when the flat occurs in the middle of nowhere at night. And I was VERY GLAD I had bought the hydraulic 8 ton jack as there was no way the tin plate wonder that was with the van would have lifted it.
