Do they pump it up and wait a while?
Discussion in 'Tech/Mech General' started by Sidney, Mar 16, 2014.
  1. Sidney
    Sidney Funster
    Jan 27, 2013
    1,279
    833
    Stamford
    MH is off for its 1st annual habitation check this week.
    I saw an episode on the caravan channel where the engineer:
    1, disconnected the gas bottle
    2, put a pump on the regulator
    3, pressurised the system with air
    4, came back later and checked the pressure was holding
    Are they still likely to do this on my MH which has a Gaslow refillable cylinder?
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    They will probably fit a service point if one is not already fitted to allow the test to be carried out. The gaslow will make no difference.
  3. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,625
    3,457
    Telford, Shropshire
    Standard gas "tightness" test is to pressurise whole system to five times working pressure, for modern motorhomes with a fixed bulkhead 30 mbar reg that's 150mbar! Five minutes "normalising" time then top up if necessary to 150mbar then it has to hold for five minutes. Don't panic about being tested at 5 times operating pressure though, 150mbar is about 2.5psi, yes two point five pounds per square inch. Any outfit that doesn't carry out a "tightness test" during a hab inspection is not doing a hab inspection.
    D.
  4. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,285
    3,730
    walthamstow east london
    is there any permissable drop with lpg ?
  5. Sidney
    Sidney Funster
    Jan 27, 2013
    1,279
    833
    Stamford
    Dave the minute this MH doesn't HAVE to go to Swift dealer I'll be on your doorstep. I suspect I'll be paying for a rubber stamp by a Swift dealer who "won't touch any warranty issues".
    • Like it Like it x 1
  6. dave newell lvs
    Oct 31, 2008
    2,625
    3,457
    Telford, Shropshire
    5 mbar after the second five minute period is acceptable. Truth is I have almost never come across a system that lost more than 1mbar after the 2nd five minute period unless there was a leak somewhere.
    D.
  7. Sidney
    Sidney Funster
    Jan 27, 2013
    1,279
    833
    Stamford
    Checked the manual for the Truma MonoControl CS (fixed regulator) and it has a test connection built in. So they should not need to disconnect anything on the high pressure or low pressure parts of the system.
  8. durhamahoy
    durhamahoy
    Jun 11, 2012
    241
    114
    Durham
    Ooh Matron
    :Rofl1:
    Steve
